Old 04-16-2006, 12:12 PM
Marello Marello is offline
Default Setting Up a Studio With ProControl...
I'm trying to help a friend cost up and plan a smallish post studio. I decided that a ProControl could be the way forward with a G5 and Tools HD but I'm still slightly confused about 5.1 monitoring. The only studio I'm used to has a Yamaha DM2000 and so all the base management/speaker calibration is done on the desk, but how would I do it using this setup?
Thanks!
Old 04-16-2006, 01:15 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Default Re: Setting Up a Studio With ProControl...
http://www.martinsound.com/pd_mmu.htm
IMDB
Old 04-16-2006, 07:39 PM
mediaguy mediaguy is offline
If you want to do it without spending a lot more than you already have then consult the manual on the Procontrol. It details how to use the analog monitor inputs on the Procontrol to adjust the different audio channels. If you want to be able to do surround panning and other effects, I recommend getting the editpack that complements the Procontrol. It also includes a keyboard and track ball which is nice as well.
Old 04-16-2006, 11:35 PM
Andy Hay Andy Hay is offline
Not quite as fully featured as the MultiMax, but also a great way to get into 5.1 monitoring + bass management - the Bluesky BMC http://abluesky.com/p_s_gb/p3s3.html
Old 04-17-2006, 08:46 PM
kcupper kcupper is offline
Marello,
Just a caveat to consider when making the decision to use Pro Control to monitor 5.1:
You can set up in two modes, stereo and surround. In stereo mode, the analog inputs give you
1. Stereo Mix (usually Pro Tools output)
2. Source 1 (CD, DAT, cassette, er....)
3. Source 2
4. Source 3
In this mode you toggle between sources depending on what you want to listen to.
In surround mode, the input sources accept six outputs from the PT interface (we patch them)
1. Stereo Mix = Lf/Rf
2. Source 1 = Ls/Rs
3. Source 2 = C/LFE
4. Source 3 = inactive
In this mode, all the sources are active, instead of toggling you can turn them on and off as you wish.
The caveat:
We calibrated our studio at 85 dB with pink noise. At 70 dB, the individual speaker levels are off by as much as + or - 2 dB from the 85 dB calibration. At lower volumes it's even worse. This is strictly a function of the cheap volume knobs Digi used on these units (million dollar theories, 50 cent parts). In my opinion, this makes Pro Control useless for surround monitoring. I'm willing to bet that this is an issue with most units, and you should definitely check to make sure that you do surround calibrations at all levels you intend to monitor at. Otherwise you will be going nuts trying to figure out what's going on with your mix.
Old 04-17-2006, 09:06 PM
CD Productions CD Productions is offline
I am using the Tascam DS-M7.1 instead of the monitor section of my Procontrol. So far so good.
Charles Dayton, CAS
Twisted Avocado Post Audio
http://www.imdb.com/name/nm0206743/
HTML code is On
Procontrol faderpack shows up as main unit in peripherals ID setting ? digigirly ProControl, Control|24, Command|8 3 05-05-2013 02:14 PM
help on setting up studio billy the kid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 05-10-2004 02:42 PM
just setting up my studio..help! brentm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-13-2003 11:27 PM
SSL AND ProControl = dream studio? Inaam Pro Tools TDM Systems (Mac) 2 01-16-2003 04:20 PM
I invite Pro Tools users to use ProControl studio but most of them use Logic????????? Jules ProControl, Control|24, Command|8 37 12-07-2000 12:10 AM
