Changing Xpand2 presets with Axiom pro 61
Each and every time I change a preset in Xpand2 using the preset increment command on my Axiom Pro (holding down soft key plugin and either right or left arrow while in Instrument mode) it defaults to the very first preset in the Pads group, no matter what group of sounds I was already in (e.g. bass).
Is this a bug that anyone else has encountered or is it perhaps a very rare form of user error |
Re: Changing Xpand2 presets with Axiom pro 61
Sounds odd Simon, can you post your complete system specs please?
filosofem |
Yeah, it is odd. I haven't experienced this with other VI's, only with Xpand2. I will be in the studio tonight finishing a song for a corporate presentation and will prod it (and other VI's) a bit more to make sure it isn't user error, but I am confident that I am pushing all the right buttons (as per DigiTV videos and the manual). WinXP sp3 AMD X2 4400+ on an Asus A8N-SLI Premium 2GB ram PTLE 8.01 Digi002r M-audio Axion Pro 61 |
Stepping through Plug-In Settings is as you are doing. Does any of the below apply?
AMD Desktop Processors The AMD processors listed below were used by Beta Sites during Pro Tools 8.0 development. They were not tested by Digidesign Engineering but are considered compatible with Pro Tools LE 8.0 for Windows:
Notes:
Not Compatible:
filosofem |
A) Have you installed the latest drivers and firmware update for the AxiomPro from the M-Audio site? Version 5.10.00.5129 for Windows XP users.
B) Have you tried reloading the template #3 Protools on your AxiomPro? C) Most importantly, you are selecting the initial bank and preset from the ProTools RTAS preset menu CORRECT? You need to do this. You cannot select from the preset selector within Xpand. The +/- buttons on the AxiomPro control movement through the RTAS presets not any on the plugin. Busch. |
filosofem, I use an AMD X2 4400+ but PTLE has always worked fine with this CPU. I can't remember if I ever installed the AMD Dual-Core Optimizer you mention. Will look into it. As it happens, I am about to buy a new intel i7 PC Thanks guys. |
Whether you are using Factory Settings or User Settings navigation should be through the Plug-In Librarian Menu. Selecting either Factory or User Settings folder then Category and finally Patch Name. Axiom Pro will only step through the Patch Names.
This I read with your first post which prompted alternatives. If the above is not how you are stepping through presets then you can disregard the alternatives. How have you setup your Xpand!2 User Settings folder? filosofem |
All is working fine now guys! Thanks for the help. Once I select presets through the ProTools RTAS menu it works as expected.
Scrolling Through Presets in Xpand2 | goat1927 | Pro Tools M-Powered (Mac) | 5 | 04-08-2023 06:16 PM |
which presets in Xpand2? | Suke | AAX Plug-ins | 2 | 09-03-2013 02:27 PM |
XPAND2 missing my patches and presets | iamkimosabi | Virtual Instruments | 1 | 06-07-2012 11:34 PM |
Xpand2 will not play defualt presets | sgaree | Virtual Instruments | 0 | 10-08-2010 04:06 PM |
Axiom 49 & xpand2 | tiger1234 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-02-2009 03:59 AM |
