Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 08-21-2006, 09:05 AM
one38productions one38productions is offline
Default Rackmount Hard Drive
Does anyone know of a good rackmounted firewire hard drive to use with pro-tools le?
Old 08-21-2006, 08:35 PM
Default Re: Rackmount Hard Drive
StorCase I'm also researching external expansion chassis. It says, transfer rates of 800Mbps (FireWire 800) but this is burst speed, not sustained transfer rate.
filosofem
Aaron Mulqueen - 001 HD Native
Old 08-25-2006, 06:07 PM
gjohung gjohung is offline
Get 2 LaCie D2 and get LaCie rack ears.
http://www.lacie.com/products/product.htm?pid=10171
Apple: MBP 2.53 - 4G RAM HDD 500G, iMac 27 inch 1TB
ProFire 2626, MBox Micro, PTMP 8, NIs, Strike, POD Farm, Logic 9, EJ Strat, 52 Tele RI, MB Mk 3, PRS CE22, Epi Casino, PBass, Variax, L6XTL, M13, DRRI, BM iGuitar, GR-33, KeyStation 88, Axiom 49
Old 08-25-2006, 06:10 PM
On Related note...I made a mistake of getting LaCie porche which is NOT PTLE compatible... so I got the D2... can I run my Virtual instruments off LaCie Porche and Session Data files on LaCie D2??
Do you really recommend separate HD for Data, Application and Plug in Sample??
Old 08-26-2006, 02:22 AM
Mike Thornton's Avatar
Mike Thornton Mike Thornton is offline
Get the Storcase FW 800 solution. It just works and when you fill a drive up just put it on the shelf and put another one in the slot. I use my rack when working on location and have no problems either transporting gear in the back of my car.
I would advise caution with LaCie drives. There have been a number of problems with PSUs and I am no longer recommending them to my clients.
Hope that helps,
Mike Thornton MIPS
Chairman Of Production Expert Ltd - home of Pro Tools Expert
Old 08-26-2006, 03:16 PM
Hi Mike, with your StorCase FW 800 are you able to Hot-Swap with that and what FW Adapter Card are you using, 400 or 800?
filosofem
Old 08-26-2006, 11:15 PM
Yes providing you unmount the drives in the normal way you are able to hot swap drives fine. It comes with a FW 400 to 800 adaptpr cable and I have used it on Apple G4 standard firewire ports. I started on FW 400 and now I have a MDD G4 I am using it on the FW 800 port.
Mike Thornton MIPS
Old 08-27-2006, 10:07 AM
Yep.. LaCie Porche does not work with PTLE... something to do with Oxford Chipset?? LaCie D2 works... it's been working for me great.
Old 09-08-2006, 07:52 AM
dickon dickon is offline
if you intend to move your gear around much get a rack drawer instead and mount drives using suppliers foam packing if suitable as this will shockmount drives a bit so they should last longer!
DAE can't get audio from hard drive fast enough, hard drive may be fragmented, there huncke Pro Tools TDM Systems (Win) 6 02-23-2010 02:06 PM
Valid Audio Drive (hard drive issue) MacPro / HD3 owenpop Pro Tools TDM Systems (Mac) 5 01-11-2008 12:28 PM
Partition Hard Drive? Clean out G$ hard drive? ike805 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-23-2006 10:23 PM
Why is my LaCie external 80 gig, 7200 rpm firewire hard drive an invalid drive to be Fucius General Discussion 4 03-19-2002 11:26 PM
Hard Drive Performance Dual Processors and Dedicated Audio Drive j_jayzatuc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-03-2000 05:52 PM
