Old 05-31-2023, 04:40 AM
TheOldestDruid TheOldestDruid is offline
Default 3 Plug-ins in the wrong path/folder
When starting my new (to me) Pro Tools 2023.3.0 it list 3 plug-ins that are missing. Click II, D-Verb, mod delay. I find them in my Windows 11 users download folder. windows > users > (user name) > downloads. I've not moved anything so how did they get there, and where should they be?
Old 05-31-2023, 06:26 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: 3 Plug-ins in the wrong path/folder
Are these installer files (.exe or .msi)? If so, you can probably just run them from where they are, and the plug-ins will install to the proper location.
If they are .aax files, then they are the actual plug-in file and should be moved to 'C:\Program Files\Common Files\Avid\Audio\Plug-Ins'
Will
System Details
Old 05-31-2023, 11:23 AM
Also the large downloaded compressed file for installing PT is in my user folder. Does it matter where it is when expanded and installing? It's naturally suspicious that the 3 missing files and the PT installation (win) file are in my user folder instead of one labeled for Avid files. Where would be a more appropriate path & folder for the distribution win file. That would be a more logical place and less prone to have misplaced files.
Old 05-31-2023, 11:55 AM
junkgear's Avatar
I'm not sure if you are downloading the installer from your Avid account or from Avid Link. In general, it doesn't matter where you install Pro Tools from.
On Windows, you should be able to right click on the large installation .zip file, choose extract and select where you wish the extracted files to located.
Here is a link to the Avid Pro Tools Installation guide, which should help you out in getting things installed correctly.
Will
System Details
Old 05-31-2023, 12:00 PM
I usually take the installation default install or unpack location. Thanks for the info. I should be able to get it sorted OK now.
PT Generate Wrong Sub-Path When Output to Track zhaojian Pro Tools 2019 1 07-10-2019 06:46 AM
Plugin folder path Bfearr Windows 3 04-24-2016 08:07 AM
Plug-Ins Alias folder points to wrong folder??? nod25 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-26-2009 03:43 PM
7.2 : wrong path assignements when multiple assign Aquarius Pro Tools TDM Systems (Mac) 2 08-28-2006 08:59 AM
Plug In Folder file path Media Man Pro Tools TDM Systems (Mac) 1 12-30-2005 05:42 PM
