Old 08-08-2013, 08:47 PM
GregJ GregJ is offline
Default Re: IK Multimedia T-Racks CS AAX
The first time I ran the installer for T-Racks 4.2, I deselected all of the VST checkboxes - because I am only using Pro Tools (versions 10 and 11).
I left the AAX, AAX 64, and Standalone boxes checked, and then I ran the 'Restore My Gear' in Custom Shop. At that point, I only saw the Classic EQ and the Metering plugin as 'singles' that would instantiate without the T-Racks Shell.
ONLY after I went back and re-ran the installer WITH the VST checkboxes checked (all checkboxes were checked) and THEN ran the 'Restore My Gear' in Custom Shop did it work.
ALL of my purchased plugins show up as Singles in PT 11 now.
Maybe this will help out someone else....
Thanks,
GregJ
Old 08-08-2013, 10:59 PM
Top Jimmy's Avatar
Downloaded and installed both T-Racks and Amplitube. I can get both of them to reliably crash PT11 and 10. Once you've made changes to the plugin settings, PT will crash if you try to remove the plugin while the transport is running.
Mac OS 10.8.4, PTHD 11.0.1
I submitted a report with IK Multimedia.
James Cadwallader
Old 08-09-2013, 12:43 AM
Top Jimmy's Avatar
Already got a reply from IK Multimedia. They must think me simple. Here's their reply:
"The work around for this issue is to stop Pro Tools before removing the plugin."
Parroted by me & Tapasquawk
James Cadwallader
Old 08-09-2013, 03:06 AM
clausiii's Avatar
clausiii clausiii is offline
Works great!
Thank you!
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 08-09-2013, 07:28 AM
Southsidemusic's Avatar
LOLLLL Good One there
Almost like - Don't move or copy the plugin while PT is running as it "might" enable clix and pops hehe..
Well atleast they are on top of things and their emails
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
  #16
Old 08-09-2013, 07:38 AM
Peter - IK Multimedia's Avatar
Peter - IK Multimedia Peter - IK Multimedia is offline
IK Multimedia
EDIT - Weird I didn't see ANY of the posts that indicate reporting issues to support (and the response, though that's a workaround and obviously there will be a fix coming for something of that nature so don't worry they don't think you are simple! :) ). SO disregard the following original post pre-edit, unless the Gain Reduction issue hasn't been reported as that definitely should be put in the official queue to look at:
Please report any issues like this to support at http://www.ikmultimedia.com/support so they can troubleshoot, verify, and possibly submit anything necessary to development. Thanks!
IK Multimedia - http://www.ikmultimedia.com
  #17
Old 08-09-2013, 12:30 PM
Benoni's Avatar
Benoni Benoni is offline
Thanks,
GregJ
Interesting. I had a similar problem, but a different solution. From the start I installed every option, but Custom Shop would crash every time I tried to restore my gear. I uninstalled CSR and T-Racks3 Standard, then just installed T-Racks CS and then I could restore my gear and get my singles.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
  #18
Old 08-09-2013, 01:04 PM
WKG WKG is offline
Originally Posted by Southsidemusic View Post
It is weird, on our HD11 the gain reduction meters doesn't show up on Mcdsp Console or Channel and when we put anyone of those on the master channel they show up Also when we have the IK "Shell" the Meters only show up when we put the compressor last
The plugins and gain reduction meters works like normal when we have one plugin at a time and don't use the IK "Shell"
I am really confused here guys
I submitted a ticket to IK support on this. The gain reduction meters don't show in any implementation in PT 11HD. Avid plugs are all fine.
We'll see what they say...
I7-4930K, X79-Deluxe, 2133 32 GB,
GT640, 512GB 860 Pro, 1TB Evo, WDB 2TB X2,
Win 10 Pro, PT Ultimate 2020.12 Studio One 5 Pro, REAPER 6
RME, Daking, Heritage, ISA, Sytek
  #19
Old 08-09-2013, 01:09 PM
IK Multimedia
I've also forwarded information about the "unchecking VST versions" issue over to some folks to see if there's a way to test this and see what's up.
  #20
Old 08-09-2013, 01:27 PM
WKG WKG is offline
This is getting odd. PT HD 11.01 works fine except for the gain reduction meter issue but when I go back to 10.3.6 I am running into 100% CPU usage and session freezing. Never had this happen prior and the only change has been the Custom shop update.
HTML code is On
IK Multimedia? lowthert AAX Plug-ins 12 09-23-2012 11:53 AM
IK Multimedia T-RackS 3 Single Module Compressor Limiter Model 670 No-Brainer Deal philip888 General Discussion 3 07-03-2011 09:45 AM
IK MUltimedia CSR stainless 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-07-2008 03:55 PM
T-Racks 24 or T-Racks Plugs? hookiefree 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 01-08-2004 01:18 PM
I'm using T-Racks and I have a problem...Anyone else using T-Racks that can help??? wcody 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-24-2000 08:34 AM
