Can any one helps me with Pro 9+ Duet one question?
I am very new to Pro 9. I tried to set it up with Duet one but the system seems not interact with each other. I was trying to select the correct inputs but only see the default selection: "Built-in" Input 1-2 on the mixer. Should I create new inputs or somethings is not connected or i need to download some updates?
Please let me know, really appreciate your help!! |
Re: Can any one helps me with Pro 9+ Duet one question?
If you've already installed the CoreAudio drivers for the Duet, you should just need to go to Setup->Playback Engine and select the Duet in the dropdown next to "Current Engine."
Hold the N key while you open Pro Tools. That should give you a window to select the DUET as your audio engine.
Duet Firewire Output 3/4 Question? | acmost | Pro Tools 9 | 2 | 11-16-2013 08:20 AM |
When Defragmenting Really Helps | NigelSpiers | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-08-2008 10:30 AM |
Tonight we'll see if anything helps with H/W-??? | Finnish | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-01-2005 02:11 AM |
nothing helps HW buffer | saorawks | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-19-2004 08:28 AM |
Thans for the helps | lcouri | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-31-2001 10:43 PM |
