Audio files "on volumes unsuitable for playback"
Please help!
I returned to my session work after a few days away. All ProTools sessions are on a Glyph hard-drive. Never have had any previous problems such as this. I open ProTools and an message reads"Original disc allocation for this session cannot be used. One or more drives could not be found or are invalid for this session. As a result, disc allocation has been modified. Would you like to verify the new disc allocation?" I proceed, and not sure what has occcured. Then, a second message reads "75 audio files are on volumes unsuitable for playback. Would you like to copy them to a suitable drive?" I select OK, and then get a message "(selected Drive) is not an audio playback volume." The ProTools session then opens with all audio files grayed out. As a test, I played some audio files from the session audio files folder using Quicktime- no problems! What might the problem be? Mac G5, 1.6 GHz 3 GB RAM OS 10.3.9 ProTools LE, v. 6.4 002R Glyph 250GB hard-drive |
Re: Audio files "on volumes unsuitable for playback"
Thank You!!! That worked!
Fritz |
Volumes set to "Transfer" only / Playback / Record...HELP! Can't open session | dudebrotherdudebro | Pro Tools M-Powered (Win) | 2 | 07-05-2013 04:21 PM |
Volumes set to "Transfer" only / Playback / Record...HELP! Can't open session | Tulipbaroo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-06-2011 05:54 PM |
"...volumes unsuitable for playback..." Huh?? | mcbv | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 11-27-2008 08:40 AM |
Audio files are on volumes unsuitable for playback | lukeyy | Pro Tools TDM Systems (Mac) | 2 | 08-30-2005 01:41 AM |
Files are on volumes unsuitable for playback. ??? | Jankku | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-25-2005 02:16 AM |
