Old 03-09-2001, 01:57 PM
jimlongo's Avatar
jimlongo jimlongo is offline
Default Import Audio dialog PROBLEM
If you have selected a file to audition and then wish to go to another folder (via Navigation's favorites menu) to select some more, the action of selecting another folder in the Nav services menu will place the file you are currently auditioning in the files to import box. Then the attempt to jump to another folder will be disallowed until you click done, add the one you had selected and return again to add more.
You can do it slowly and manually, but not with Nav services favorites. This is a very slow way to work.
[This message has been edited by Jim Longo (edited March 09, 2001).]
noise | jimlongo
Old 03-12-2001, 03:32 PM
jimlongo's Avatar
Default Re: Import Audio dialog PROBLEM
I can't believe I'm the only one experiencing this. I'm trying to use navigation services to jump to other folders, but whenever I do it adds the file that I am currently sitting on and then can't jump. What gives...this sucks.
noise | jimlongo
Searching in Import Audio Dialog Submersible Pro Tools TDM Systems (Mac) 2 05-20-2007 01:22 PM
I cant preview audio in digibase or import audio dialog. sammyfarr Pro Tools TDM Systems (Mac) 0 03-29-2007 01:16 AM
Small "import audio" dialog bug? thierryd Pro Tools TDM Systems (Mac) 0 12-10-2006 04:24 PM
Import Audio dialog , Can't select or play audio Irl Sanders Pro Tools TDM Systems (Mac) 11 10-04-2006 02:02 PM
5.1.1 Import Audio Dialog - another change? barden Pro Tools TDM Systems (Mac) 1 06-29-2001 02:35 PM
