This is a newbie question..
In a project with 12 tracks, when I select the second one track one and three are also selected at the same time ie they go dark. If I try to trim the first one all three get trimmed! how do I stop this? I have tried using group and un group but to no avail. Also if I have a stereo track but only have audio on the left channel. How would I go about duplicating the left channel and putting it in place of the right creating a stereo track? I know these are stupid questions but I can't get past them.. Any help would be great! Cheers -Ben |
First of all...there are no stupid questions...
For your first prob:delete all the groups you have created or disable'em all.Make sure in the group section, the All group is disabled too. Maybe stupid answer but when you select your region, use the selection tools directly in the edit window (and not using the blue locator as a selection tool on the timeline). For your second issue, I don't really understand if you've tried to drag a mono track in a stereo track (if yes, there's no point to waste a track for that).After if you want a kind of emulated stereo track, put your mono track on a mono track, then duplicate the track, select them both and drag it onto your stereo track.It will still sound mono anyway so shift one of them of about few samples before in Spot mode (about 0|0|007)then drag the set on the stereo track.I don't if that's what you wanted to know.Hope it helps. |
Regarding "the darkness"...
Are the tracks grouped? If so you need to ungroup them in both the Mix and Edit windows. Hope that helps...ran into that this week and folks here helped me out. |
select a single region with the grabber tool selects all regions | dinzer47 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 03-22-2019 01:15 PM |
Key command to name adjacent regions in PT8? | djmendoja | Post - Surround - Video | 5 | 03-30-2009 01:00 AM |
Key command to name adjacent regions in PT8 | djmendoja | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-26-2009 08:32 PM |
Superbasic q selecting non-adjacent regions | Karl Engel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-05-2006 01:01 AM |
Volume automation in adjacent regions | pbjnus | Pro Tools TDM Systems (Mac) | 0 | 10-05-2004 03:33 PM |
