Converting Space Designer Settings to tfx
Is there an easy way to convert Space Designer Logic .pst settings to Pro Tools .tfx settings? I can do it one at a time, but I'd love to find a faster way (there are loads of different settings!!) Is there an application that can do this to a bunch of files at once?
Thanks, Nic |
Re: Converting Space Designer Settings to tfx
I´d like that, too!
Peter
http://www.merlinsound.de |
I've done all the Logic factory ones already. I'm on the road this week but email me next week and I'll send them to you.
Jeff |
Thanks Jeff!
If I remember correctly, the presets using the generated IR samples converted fine.
The presets using the sampled IR's (SDIR files I think) required converting the SDIR samples to AIFF files, as the HTDM version of Space Designer would not recognize them. I did that as a batch with Peak. If anyone knows a solution, let me know about it before I send out these presets next week and I'll fix them. |
excuse my ignorance, but where do you get an HTDM version of Space Designer?
Thanks Mark |
If you have the emagic htdm enabler and the most recent update from emagic.de website, Space Designer shows up in Pro Tools along with several htdm instruments like evp88 etc. Unfortunately, the htdm enabler is a discontinued product, so it's tough to find if you don't already have it.
Nic |
You also need to have Space Designer type A code in your XS key to permanently enable ...
http://www.ainsliegrosser.com/ MacBook Pro 2019 64GB OSX 10.15.7, HDX, Sonnet Chassis, PT Ultimate 2022.9, S3, Dock, MTRX Studio |
Logic HTDM Space Designer Issue | antonis | Digidesign Hardware & Software | 0 | 12-06-2009 03:43 PM |
space designer (epic/host tdm) in pt 7.4 does it work??? | ejsongs | Pro Tools TDM Systems (Mac) | 5 | 06-13-2008 12:21 AM |
Using Logic EQ's Revebs and Space Designer in PT | glenfield | Pro Tools TDM Systems (Mac) | 29 | 10-06-2005 08:12 AM |
Space designer for Pro Tools? | M2E | Pro Tools TDM Systems (Mac) | 24 | 03-20-2005 01:21 PM |
SAME SPEED AT DIFFERENT CONVERTING SETTINGS??!! | lukthehook | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-09-2001 01:17 PM |
