Latency issues
If you have latency issues, should you increase or decrease buffer size?
Re: Latency issues
You should decrease the buffer.
A decreased buffer will make your sound go through your machine faster but at the same time it will also make your hardware need to work harder. What's your interface and what are your buffers set to now? Also, what are your computer specifications?
Marcel Risberg Production sound and audio post - ljuddesign.se Enthusiastically sharing knowledge and experience at Stockholm Film School. 🛠 Pro Tools Ultimate 2019.10 · HD Native · HD Omni 🎚 EuControl x.x.x · Artist Control · Mix · Control App 🦑 MacPro5,1 · 12C24T @3.46GHz · 48GB · SSDs · macOS 10.13.6 (17G5019) 📺 Separate video playback machine 🥇 Covered by ZDT/TLC · Keeping DAW OS clutter free |
Re: Latency issues
Re: Latency issues
Did you try setting the buffer to 128 or even 64?
Your machine seemed quite fast judging by the specs. What OS? Is it a Mac?
Re: Latency issues
Its a pc. A higher end laptop. What actually cause latency issues?
Re: Latency issues
Look at it this way: The system as a whole affect latency. Choose your components wisely and don't forget to be creative about it. For example: A bigger session might require you to increase the buffer size / latency to be able to run on your machine. A smaller sized session might allow you to decrease the buffer which shortens the latency. Some times when I need to record something which requires a minimal buffer size but my session is to big for my machine to handle at a smaller buffer - I bounce my session with hundred tracks down to a two track session, record at ultra low buffer settings, and then import what I just recorded back to the larger session .. and voila. This is a fairly decent article with pictures describing what latency is about: http://www.presonus.com/community/le...-audio-latency
Re: Latency issues
Re: Latency issues
Latency Issues | dmils | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 07-24-2010 08:09 PM |
Latency Issues - changing latency has no effect | Kippa-Dee | Pro Tools M-Powered (Win) | 1 | 07-15-2010 08:39 PM |
Latency Issues, Please Help!!! | daveseviltwin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-19-2010 07:01 PM |
latency issues | stainless | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-23-2009 08:27 PM |
LATENCY ISSUES WITH 7.3.1 | KRAFT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-30-2007 09:23 AM |
