Old 07-18-2021, 06:30 PM
jefeboy jefeboy is offline
Default "Unable to communicate with HUI"
Trying to set up Pro Tools for the first time, and I can't get it to recognize my M-Audio Oxygen Pro 49. I've tried setting it up as its model name and as an HUI and in both cases I get the alert in the title.
It's connected to my Mac via USB>USB-C adapter.
It does show up under MIDI input devices, but it doesn't recognize that I'm playing it.
I read to set it up in the Peripherals window as HUI, and I set both receive and send to USBMIDI.
The keyboard works fine with Garageband so I know that's not it. Any ideas what I should try next?
Old 07-18-2021, 07:41 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: "Unable to communicate with HUI"
If you're just trying to record MIDI from the keyboard, you shouldn't have to set up HUI. You should be able to show Instruments on the Mix window and select the MIDI in/out devices and MIDI channels, assuming your keyboard is showing as an option there. That's how it works for me at least.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 07-18-2021, 07:52 PM
Well I would like to try to use the HUI functionality also. But I was getting the same error message even when I was setting it up just as a keyboard. Either way it’s unable to communicate with it.
Old 07-30-2021, 01:37 PM
DetroitT's Avatar
DetroitT DetroitT is offline
USB>USB-C adapter. Apple brand?
Maybe try different port.
macOS?
Using Eucon?
Old 07-30-2021, 02:31 PM
Keyboard controllers for recording midi need to be set up under the Setup>Midi>Midi studio menu. Peripherals is for HUI controllers, Eucon Controllers and similar(among other things)
Old 07-30-2021, 05:55 PM
cwsand's Avatar
Apparently this keyboard has HUI functionality that has to be set up correctly on the keyboard and in Pro Tools.
I found this, maybe it will help:
https://inmusicbrands.force.com/akai...p-in-Pro-Tools
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
"Pro Tools is unable to communicate with HUI" lukew92 Getting Started 7 07-06-2020 02:24 PM
M-Audio Projectmix IO - "pro tools unable to communicate with hui" Red Yeti Studio FireWire & USB Audio Interfaces (Win) 2 05-30-2016 06:38 AM
PT 12 and Digi 003 "unable to communicate" error tbunch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-15-2016 09:48 AM
"ProTools is unable to communicate with Motormix" ISedlacek 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 05-05-2003 12:21 AM
