Old 03-09-2011, 04:59 AM
Jupiter4 Jupiter4 is offline
Default (-6101) Error. Please Help.
I've been using Pro tools for about 10 years and I like it but recently it has become unusable and I have started moving to logic. I don't want to do this but Pro Tools just seems incompatible with my mac or osx in general or something!!!!!
My setup:
Mac Pro (about 5 years old)
2 x 2.66Ghz Dual Core Xeon
6GB Ram
OSX 10.6.6
Interface 003+
Pro Tools 9
Plugins: I've got loads but at this stage the majority are out of the plugins folder and I only have avid plugins in there (I also trashed databases & prefs after moving them from the plugins folder).
I have tried (almost) everything on the trouble shooting and system optimization pages as well as any other trick I could find but I still get the (-6101) when I try to bounce.
I also have gotten these quite regularly:
(-6097)
Lost communication with the audio interface. Please try increasing "H/W Buffer Size" or removing some plugins, and make sure you have a valid clock source. Press OK to reset device. (-6097)
(-6093)
The Operating system held off interrupts for too long. if this occurs frequently, try increasing the "H/W Buffer size" in the playback engine panel. (-6093)
occaisionally:
(-6086)
(-9128)
You are running out of CPU power. Remove some RTAS plugins or increase the CPU Usage Limit in the playback Enigine dialog. (-9128)
And of course when trying to bounce, the classic:
(-6101)
A CPU Overload occurred. If it happens often, try increasing the "H/W Buffer size" in the Playback Engine, or removing some plugins. (-6101)
Some of these were fixed by me turning off my 003+ and selecting internal input/outputs but that doesn't seem like a great solution seeing as I spent a lot of money on that piece of hardware.
Is my computer simply too old?????
Should I give up and just move to logic which seems to not have any of these stupid stupid problems.
As you can tell this is somewhat frustrating and I'm already 2 days behind on a fairly big job.
If anyone can help I'd greatly appreciate it. Thankyou
Old 03-09-2011, 09:37 AM
DigiTechSupt's Avatar
Default Re: (-6101) Error. Please Help.
Have you tried all the troubleshooting and optimizations from the General Troubleshooting thread yet? If not, I'd start there...
Avid Audio Tech Support
Support FAQ
Old 03-09-2011, 05:54 PM
Yes. As mentioned in my post, I have tried almost all of the steps suggested in trouble shooting and system optimization. The few that I didn't try were things that weren't relevant to my situation.
Old 03-13-2011, 10:01 PM
Still no progress, does anyone have any suggestions? Is my computer too old and I'll just have to switch to logic?
Old 03-23-2011, 11:13 PM
Java Java is offline
What's the model number of your mac. You will find it in system profile under the Hardware overview. If your computer is older switching from a newer version of Pro Tools to a newer version of Logic may very well put you in a worse situation. You will add learning a new program to the original problem of legacy hardware.
Java
Error -6101 in PT 10 Cutlerbri Pro Tools 10 5 03-18-2014 02:08 PM
PT 10.3.5 DAE error -6101 Jazzbass56 Pro Tools 10 5 07-03-2013 09:33 PM
PT 10.2 6101 error. NEED HELP! Stijn Cole macOS 0 07-01-2012 02:27 AM
PT 10.2 6101 error. NEED HELP! Stijn Cole macOS 0 07-01-2012 02:26 AM
Just another CPU, -6101 error... Seraplane macOS 3 02-25-2011 11:37 AM
