First I had PTLE 8.0.4, then thought I would try an update to 8.0.4cs2. I still have the problem.
Windows 7, 64-bit. I cannot change the buffer rate. Line 1-2 of my 002 are defaulted as the Windows playback device. There is no way for me to unattach it (that I know of). I've heard that if it is attached to Windows, it will "lock in" the buffer rate at 256 samples. Here's my SANDRA report. ------------------------------------------ SiSoftware Sandra Computer Model : EVGA 122-CK-NF68 Workgroup : WORKGROUP Host Name : AustinMusicPC User : Austin Processor Model : Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz Speed : 2.83GHz Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 2x 6MB, ECC, Synchronous, ATC, 24-way, 64 byte line size, 2 threads sharing Computer Mainboard : EVGA 122-CK-NF68 BIOS : Phoenix Technologies, LTD 6.00 PG 09/04/2008 Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 8GB DIMM SDRAM Chipset Model : nVidia C55 Host Bridge Front Side Bus Speed : 4x 333MHz (1.33GHz) Total Memory : 8GB DIMM SDRAM Memory Bus Speed : 1x 800MHz (800MHz) Memory Module(s) Memory Module : G.Skill F2-6400CL5-2GBPQ 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-15 3-23-6-3) Memory Module : G.Skill F2-6400CL5-2GBPQ 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-15 3-23-6-3) Memory Module : G.Skill F2-6400CL5-2GBPQ 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-15 3-23-6-3) Memory Module : G.Skill F2-6400CL5-2GBPQ 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-15 3-23-6-3) Video System Video Adapter : ATI Radeon HD 4600 Series (320 SM4.1 750MHz, 1GB DDR3 2x800MHz, PCIe 2.00 x16) Video Adapter : ATI Radeon HD 4600 Series (320 SM4.1 750MHz, 1GB DDR3 2x800MHz, PCIe 2.00 x16) Video Adapter : ATI Radeon HD 2600 XT (120 SM4.0 800MHz, 256MB DDR3 2x700MHz, PCIe 2.00 x16) Graphics Processor Adapter : ATI Radeon HD 4600 Series (320SP 8C 750MHz, 1GB 2x800MHz) Adapter : ATI Radeon HD 2600 XT (120SP 3C 800MHz, 256MB 2x700MHz) Storage Devices Seagate ST3250410AS (250GB, SATA150, 3.5", NCQ, 16MB Cache) : 233GB (C:) Seagate ST3250410AS (250GB, SATA150, 3.5", NCQ, 16MB Cache) : 233GB (E:) LITE-ON DVDRW LH-20A1H (ATA66, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:) Logical Storage Devices Hard Disk (C:) : 233GB (NTFS) @ Seagate ST3250410AS (250GB, SATA150, 3.5", NCQ, 16MB Cache) Xenon (E:) : 233GB (NTFS) @ Seagate ST3250410AS (250GB, SATA150, 3.5", NCQ, 16MB Cache) Optical Drive (D:) : N/A @ LITE-ON DVDRW LH-20A1H (ATA66, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : nVidia MCP55 LPC Bridge LPC Legacy Controller 1 : Winbond W83627DHG Audio Device : nVidia MCP55 High Definition Audio Audio Codec : Realtek Semiconductor Realtek 885 High Definition Audio Audio Device : PC Partner R700 Audio Device [Radeon HD 4000 Series] Serial Port(s) : 1 Disk Controller : nVidia MCP55 IDE Disk Controller : nVidia MCP55 SATA Controller Disk Controller : nVidia MCP55 SATA Controller Disk Controller : nVidia MCP55 SATA Controller USB Controller 1 : nVidia MCP55 USB Controller USB Controller 2 : nVidia MCP55 USB Controller FireWire/1394 Controller 1 : nVidia TSB43AB22 1394a-2000 OHCI PHY/Link-Layer Controller FireWire/1394 Controller 2 : Procomp Informatics TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller SMBus/i2c Controller 1 : nVidia MCP5+ SMBus 1 SMBus/i2c Controller 2 : nVidia MCP5+ SMBus 2 Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : hp psc 1300 series (1200x1200, USB, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : HP Photosmart C6200 series (600x600, USB, Colour) Scanners and Cameras Scanner : Hewlett-Packard HP psc 1300 (Scanner, 2400x2400, USB) Network Services Network Adapter : NVIDIA nForce Networking Controller Network Adapter : NVIDIA nForce Networking Controller #2 (Ethernet, 100Mbps) Wireless Adapter 1 : Broadcom 802.11g Network Adapter Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 5.9 Performance Tips Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
I'm not the expert here, but I would go into your sound properties(Control Panel>System>Hardware>Device Manager) and tell Windows to use the onboard audio(in theory, freeing up the 002 for Pro Tools use). Then, to hear non-PT sound thru your monitors, run a mini plug to dual RCA cable and patch to the Alt inputs on the 002. Hit the Alt to Mon button to hear all non-PT audio(and never get a message that some program is using the 002 when you want PT to use it).
HP Z4 workstation, Mbox Studio https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix ![]() BTW, my name is Dave, but most people call me.........................Dave |
![]() Quote:
Thanks. What I don't understand is why aren't there many more posts about this issue? Surely I and the other one or two people I saw post about this aren't the only ones using PTLE 8.0.4 on Windows 7 64-bit having this issue.... |
I've had that happen a few times, but I've typically found that if I quit any other applications that are making sound I can go back into pro tools and change the buffer size. I'm not using cs2 yet, but I'm on cs1 with a 002.
I was using the 'alt src to mon' for a long time before avid opened up the 002 for windows to use as a soundcard. I just find it so much more convenient to use the 002 directly as a soundcard. There's also no signal interference this way, whereas I had a good bit of noise coming into my rca cables. |
Big Crouton, by gosh it worked. I used to have to do that in order to open a session with a 48 kHz sample rate, because other apps were latching onto the 002 and keeping it at 41 kHz. I guess they do the same thing with the buffer rate...
Thanks a lot for the insight, guys. |
That works too. My method eliminates the software conflicts
I just returned from RadioShack where I picked up some RCA and 8mm connectors.. so I'm still going to use your method for when I'm running a non-41 kHz session and want to listen to Windows sounds. :P
ProTools 8 Won't Startup, Can't change sample rate, Can't change h/w buffer size! | Nickford | Windows | 0 | 05-26-2013 11:20 AM |
Unable to change sample rate or buffer size with 11R | MattBaron | Eleven Rack | 5 | 03-05-2012 03:39 PM |
Cannot change HW Buffer Size higher than 1024 Samples | shawnj | macOS | 1 | 02-25-2012 04:42 AM |
HW Buffer error 6085 on PT LE 8.0.4cs2 | mj23 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-25-2011 08:37 PM |
can't change h/w buffer size above 128 samples | mmiller | Pro Tools M-Powered (Win) | 6 | 07-24-2010 10:42 AM |
