Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 02-22-2010, 08:52 PM
jrwallace jrwallace is offline
Red face Loop tracks stuck together - change 1 change all
* Mac Book Pro 3,2; Intel Core 2 Duo; 2.2GHz processor
* OS X 10.6.2.0 - Snow Leopard
* Pro Tools M-Powerd 8
* 2MB RAM
* Attached Hard Drives: LaCie, G-Drive attached via USB Hub
* Attached USB: M-Audio Keystation 49e directly to computer
* M-Audio Firewire 1814 attached directly to computer
* project files running off of LaCie Hard drive
CONTEXT
Thank you in advance...! I am new to Pro Tools so the answer may be quite simple.
OVERVIEW
I am using the Pro Tools loops disc that came with the software package. Once the loops overlap in the timeline (this has happened with previously recorded audio as well) I am no longer able to make changes to individual tracks. When I move 1 track down the timeline, all the other tracks move as well; When I move the fader in 1 track, all the other track's faders move as well. Some of the times that this has happened there may be one track that is able to move independently but if you select any of the other tracks it is group with them.
It is as if they are synced or grouped. However, I have been unable to fix it or find answer via those search terms.
MORE DETAIL
* I have created the tracks by both dragging below existing tracks, allowing pro tools to automatically create tracks AND by dragging to an existing instrument track.
* I have tried selecting different modes (i.e Slip, Shuttle, Grid and SPot) and the problem persists.
* I have tried selecting the different tools and deselecting different tools (i.e. mirrored MIDI editing, insertion follows playback, etc.)
* I have tried changing the order of the tracks.
ANY ideas?
Old 02-22-2010, 09:19 PM
brothermunk brothermunk is offline
Default Re: Loop tracks stuck together - change 1 change all
Check in your groups folder, (down in the bottom left of the arrange window) and see if 'All' is selected. If it is then any automation or track volume adjustments you do to one track will affect all channels.
Maybe you have checked this, but thought id chip in
Why is my fader stuck and I cant get it to change the volume in the mix? RuffinMedia macOS 5 02-22-2012 02:22 AM
why is my fader stuck and i cant get it to change the volume in the mix? Jahlal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-06-2010 06:58 PM
Can Pro Tools change the key of a loop? TQ1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 11-13-2007 09:09 AM
How to change the tempo of a loop in PT LE? cary chilton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-30-2006 06:05 AM
882/20 i/o stuck in -10... how do I change it??? Questar Pro Tools TDM Systems (Mac) 3 11-15-2004 04:03 PM
