Old 02-22-2006, 03:00 PM
Howardk Howardk is offline
Default > HD - Audio leak thru track w/ no voice assigned
A strange occurrence. I often just turn-off the voice for tracks I am not using (old habit from before we could park tracks). I did this last night and later noticed I was still hearing audio from a mutted track. . . Took awhile, but I found this ghost audio was leaking thru this track with the voice turned off (it did not show on the meter, but it sounded and a mute stopped it). I changed the voice to Dyn and it was fine, changed the voice to off again and it was still silent. The same thing happened a litle later on with another track that had the voice off. Strange. . .
Parking the track is the easy fix, but I thought I should mention it in case it puzzles someone else, and a little bug noticed can sometimes help solve other bigger problems. . . I did not have time to test any further because I was tweaking a mix with client.
Also, still having a lot of problems with NI VI's (Distortion, Random noises). . . Looks to me like single processor mode performs better than Dual.
System:
PT 7.1 cs3
OSX 10.4.3
HD4 (Core + Accel + 2 x Process)
G4 Dual 1.42GHz w/ 1.5 GB RAM
...for system configuration info see my profile
(Click on member name)
Foot switch for effects assigned in track. Schumannz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-03-2012 11:56 PM
PT plays MIDI input even if not assigned to a track j20056 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-26-2009 07:36 AM
Mute Frees Assigned Voice - question Dopamine Pro Tools TDM Systems (Mac) 2 11-11-2008 02:52 AM
Mute Frees Assigned Voice save bug RIO Pro Tools TDM Systems (Mac) 0 08-09-2006 12:10 PM
help.....A track has an invalid TDM connection. Make sure all tracks are assigned to yang jung-hoon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-02-2003 10:49 PM
