MXF audio for feature film mix in PT
Hello,
I recently upgraded our Avid Media Composer SFX library to 24-bit audio as we'd like to work in an all 24-bit audio environment. I wasn't paying attention when I brought everything in and imported everything as 24-bit MXF audio (rather than WAV). This will have no impact on our editors but I'm concerned about when we send all of the audio in our final cut to Skywalker for the final mix. In the past we'd give them the OMFI folders from the Avid so they easily had everything they needed. I believe I heard that the latest Pro Tools does support MXF audio. Does this mean one can simply bring in the audio without having to convert it first? Should I be worried about this? It's not too late to convert everything over to WAV files as our next film is just getting started but it's a huge job. Thanks for any feedback regarding this. -Cablet |
Re: MXF audio for feature film mix in PT
They will be able to either work directly with the AVID MXF media or covert it when opening the AAF to BWAV. MXF does put a heavy strain on PT because of the very big wrapper but it has gotten better under PT10.x. But below the line: Yes you can work with MXF audio directly in PT. Frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
one catch, Elastic Audio will not work on MXF files
everything can be converted on import, if you give them a heads-up
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
5.1 surround mix for feature film | finalmixaudio | Post - Surround - Video | 32 | 03-12-2014 10:03 AM |
Feature film facility | Sorna | Post - Surround - Video | 18 | 12-26-2012 04:28 PM |
HDX for feature film work | The golfer | Pro Tools HDX & HD Native Systems (Mac) | 6 | 03-14-2012 10:48 PM |
HDX for feature film work take 2 | The golfer | Post - Surround - Video | 28 | 03-06-2012 01:19 PM |
Feature film announcement. | MunchieLad | Post - Surround - Video | 0 | 05-14-2005 10:48 AM |
