Old 09-15-2021, 02:13 PM
BLRStudios BLRStudios is offline
Default Hardware insert not working on particular track
I have a routing folder set up for my lead vocals and for the life of me I can't get them to pass through my 1176. The GR meter on the 1176 is rocking but I'm not getting any audio at all. I thought I was dealing with a faulty connection but if I put the same insert on any other mono track, it works as expected. Checked my I/O in PT and my Apollo software and both are correct. Has anyone else had this issue or can you think of anything I could be overlooking that would cause this?
Old 09-15-2021, 07:26 PM
noah330 noah330 is offline
Default Re: Hardware insert not working on particular track
Do you have a mono/stereo plug inserted on the channel?
Apple M1 Mac Studio (base model)
ProTools Carbon w/SSL XLogic MADI-AX
Instagram:
https://www.instagram.com/sparkletune/
Old 09-15-2021, 10:44 PM
I don't. If I move the insert down to the next level of the folder, it works again. I tried deleting the old folder and making a new one with a new name but no dice. I've also tried doing Save Copy In... thinking it could've been an issue with the session but again, no dice. I'm stumped.
Old 09-16-2021, 01:00 AM
Emi's Avatar
Emi Emi is offline
Try trash preferences.
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3
Old 09-16-2021, 09:38 AM
I couldn’t believe I hadn’t done that earlier but it still isn’t working. Like I said, it’s been working with this routing for a while. The only thing that had changed is I had reinstalled the UAD software so I trashed all of that, reinstalled but, again, didn’t help. I’m at a loss.
How do you copy a stereo track's insert to a mono track? moshuajusic Pro Tools 2020 9 12-31-2020 07:33 AM
Pro Tools 11 Hardware Insert Not Working redparade Pro Tools 11 3 10-07-2016 05:24 AM
Hardware insert 1&2 cutting off other hardware inserts on aux tracks Led Windows 4 12-09-2013 09:19 AM
How to insert hardware as channel insert Lqoau 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-19-2012 07:29 AM
How can I insert a hardware effect into my master track? Animal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-14-2002 01:42 PM
