Need Help installing plugins...
Hello all
My setup is MBox2 Mini (plugged into left side usb port as recommended by digi), ProTools LE 7.3.1cs4, MacBook Pro 2.4GHz Core 2 Duo 2GB memory. External drive is EZQuest 160GB 7200RPM Firewire 800. I have recently switched to Mac and I am having much difficulty installing plugins. I have tried various types of plugins including free online, free digi plugins, and others. For whatever reason, after installation, they do not appear in the plugins window. They also do not appear in the AudioSuite menu. My friend said it is because I have an intel-based Mac and there was something I needed to run/install but I could not find it. Any help is appreciated! =) |
Re: Need Help installing plugins...
Well, you need to be sure that the plugins you are installing are the "LATEST UB (Universal Binary) or INTEL versions of the plugins.
if you install older PPC (PowerPc - ie G4, G5) versions of the plugins, they won't load when Pro-Tools loads, and won't show up in Audio Suite, or in your plugins list. All of the manufacturers will have UB or Intel versions on their site, or through contacting their customer service, or Support.
David - MacStudio M1 - HDX II Sonnet xMacStudio - 16x16 HD i/o x 6 - PT ULTIMATE - SONOMA - ProTools Dock / S1 / Control App |
PT 10.3 & 11 Installing Plugins | CraveMac | macOS | 12 | 11-04-2013 09:31 AM |
installing a set of plugins, how do I do that? | thinksamuel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-11-2007 06:59 AM |
installing plugins | aishabag23 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-06-2004 02:36 PM |
installing plugins? | romerom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 03-12-2004 01:07 PM |
help installing plugins on the 001/mac | t ho | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-25-2002 03:22 PM |
