Old 01-20-2016, 05:24 PM
cabdriver cabdriver is offline
Default Driver_IRQL_Not_Less_or_Equal
So, I just set up my new computer and put Pro Tools on, installed the driver for the interface, plugged in the firewire, and can go about my business for a while, but eventually, the computer will crash unexpectedly, the BSOD showing driver irql not less or equal and points to avidmboxpro.sys as the culprit. I haven't used Pro Tools yet (as I don't want the computer to crash whilst I'm working on a project). It ran Sibelius smoothly with no problem. I suspect it's a conflict with the on-board sound card/driver, as the computer has only crashes while I'm streaming audio/video from the internet. I have updated every driver (from device manager, I'm not sure if there are drivers I must update manually), I've disabled the HDMI audio driver, and reinstalled the Mbox drivers again. I'm not sure what else I should do; any suggestions?
Windows 7 Home Premium OEM, 64 bit
8Gb ram
3Ghz AMD processor
Pro Tools 8 LE
Mbox Pro 3
Realtek High Definition Audio
Old 01-22-2016, 04:27 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Driver_IRQL_Not_Less_or_Equal
Hi, It could be a compatibility issue with the firewire port - chipset or driver. Posting a SANDRA report as described here might help: Help Us Help You
Here's a link to some info on Avid Qualified FireWire Cards for Windows
You might also try this:
Enable Legacy FireWire Controller
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 01-22-2016, 04:37 PM
And installed exactly what driver version?
Old 01-25-2016, 09:59 AM
It's the most recent driver, 1.1.10. I've checked it's compatibility (works with PT LE 8.04, Windows 7), but one thing that worries me is that, when checking the drivers, avidmboxpro.sys is not digitally signed. Considering that that is the file the BSOD points to, would the lack of a signature be cause for alarm?
Old 01-25-2016, 03:09 PM
You are really using an Mbox 3 Pro with Pro Tools 8 LE? That authorizes LE OK? Has that combo ever worked?
I kinda doubt Avid tests or officially supports this combination. Where did you see the claim that Pro Tools LE 8 is supported for that driver?
Has this Mbox 3 Pro ever worked OK on any other system? With Pro Tools 8 LE?
Not that any of that explains the blue screen here, but I am not sure this will work at all. For that you may well be into debugging the FireWire card, trying the FireWire legacy driver etc. has this FireWire card ever worked with this Mbox 3 Pro? Post a Sandra report as expected. Start at the "help us help you" link up the top of this web page.
Old 01-25-2016, 10:19 PM
I've had this for 4 years, 8 le has not had a problem with the Mbox 3 Pro
Old 01-26-2016, 05:43 PM
So, the AvidMboxPro.sys file is the only driver file on my desktop that isn't signed. Can I get a signature or a signed replacement file?
Has anyone ever had a problem like this?
Old 01-26-2016, 05:52 PM
Not being signed is not the problem. Multiple posts here have suggested you look at the firewire card and legacy mode etc. have you done any of that?
Old 02-04-2016, 11:35 AM
T'wasn't the legacy mode. Fixed it by re-seating the card. Problem is now that every so often the sound'll cut out; no freezing or crashing, just losing the sound. I can fix it by pausing the video/audio for 10-30 seconds. Any way I could figure out how to stop it from cutting out?
Old 02-04-2016, 01:41 PM
System fully optimized?
Trashed prefs and databases?
What make/model/spec dedicated audio/session drive are you recording to? How is it attached? (USB2, Firewire 800, SATA III?)
What payback engine buffer size?
Make sure "ignore errors" is not checked.
If that does not work I'd try a different Firewire card, just any different physical card with a TI chipset.
DRIVER_IRQL_NOT_LESS_OR_EQUAL, then- BSOD TOMsubG Pro Tools SE and Essential (Win) 0 11-28-2011 04:57 PM
driver_irql_not_less_or_equal / BSOD when shutting down zygzag420 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-24-2007 11:54 AM
