Old 04-24-2020, 03:09 PM
paulschwotzer paulschwotzer is offline
Default HDX fan noise in MacPro 7,1
In a 2010 cheese-grater MacPro my HDX fans are on (and noisy) a lot.
The new MacPro 7,1 is apparently very quiet and well ventilated.
For anyone running HDX cards in a new MacPro:
Any chance that the card cage is cool enough so that the HDX fans do not need to turn on?
BTW, my HDX fans are on whenever the the ProTools app is running whether or not I'm doing much processing.
Old 04-24-2020, 03:11 PM
Marsdy Marsdy is offline
Default Re: HDX fan noise in MacPro 7,1
Have you checked if your HDX card and 2010 Mac Pro aren’t clogged with dust? It makes a BIG difference to airflow.
Dave Marsden
UK
Old 04-24-2020, 03:30 PM
Joe Courtney Joe Courtney is offline
The New Mac Pro has three big fans in the front that draws a ton of air and they are dead quiet.
Old 04-24-2020, 11:31 PM
LukeHoward LukeHoward is offline
Mine seems pretty quiet, although it's hard to tell with all the other noisy stuff in my rack (I'm looking at you, Avid I/O although my Ethernet switch is actually the noisiest).
Before moving my HDX card to the new machine, I took the cover off and gave it a good blow with some compressed air. (I have a theory that the thermals could be more efficient without the fan but I'm not about to try and find out by removing it and connecting a dummy load!)
https://lukehoward.com/
Old 12-07-2020, 12:55 PM
resonantRhythm resonantRhythm is offline
When I had one HDX card...I noticed that the fans only came on when I was running Pro Tools...but I've added a second card and now at least one fan is ALWAYS running...
I am trying to find out how to fix this because it's absolutely silly!
I have a new rack MacPro and without the HDX cards you wouldn't notice it was at your feet. Granted with music playing you don't hear it but as soon as you pause you can hear the whir of them.
Old 12-07-2020, 09:53 PM
bzone bzone is offline
Try firmware upgrade for each card. Had the same issue with one of my cards at new install. All silent now.
Old 12-08-2020, 06:36 AM
MixerGuy MixerGuy is offline
I have a 2020 MacPro and HDX2 in it
when i first boot the Mac with HDX-2 is very quiet.... after maybe 30 mins running the HDX fans kick on, but on low....
i suggest some sound baffles, and also some distance from you. This helps a bit.
and yes, for sure the firmware update to the HDX cards.
Old 12-08-2020, 10:23 AM
Am I missing something with updating the firmware or does Running Pro Tools not trigger the latest update? I have the latest HD Driver installed with the latest Pro Tools.
Old 12-08-2020, 03:37 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Card firmware, not driver.
After a fresh restart. Run Digitest (In Utilities)
There you can see the version numbers (Avid Hardware) for a variety of components.
And can upgrade if needed.
Old 12-08-2020, 05:28 PM
Yes when I first booted with 3 cards all were in high fan mode. Did the digi test and it picked out only one card that needed the firmware update. It scans all cards and will notify you 1/2 or 2/2 etc. The program comes up and updates everything. Then when completed, the fans cut off. I did have issues with the driver, when I called Avid I was transferred to some idiot that was in a foreign country arguing with his wife and looking on his computer to find data and the correct answer I was looking for. I hung up on him and searched all the forums to find the firmware answer. Good luck, it should solve your problems.
White Noise, distortion, pops, loud noise in Pro tools 9 and mbox mini Bigpit Windows 1 09-09-2013 09:26 AM
Audio Recording Noise Test on a new laptop.How do I reduce fan/system noise? PeterGreen Pro Tools 10 24 01-23-2013 06:38 AM
Using carbon copy to move from macpro to a newer Macpro fourthtunz Pro Tools TDM Systems (Mac) 2 04-10-2012 02:39 PM
Attn: Drumkit from Hell experts: noise noise noise Smelt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 07-30-2003 06:31 AM
Fast panning produces noise like a noisy pan pot! Is this "Zipper noise?" Jules Pro Tools TDM Systems (Mac) 4 03-02-2000 03:12 AM
