Old 05-18-2014, 12:54 PM
Captain Whisky Captain Whisky is offline
Default Drum Replacer, out of syn
Si I'm trying to replace my kick on the drums, going through the usual process and it works. But as you zoom in on the kicks further up, it's not exactly dead on and it seems to vary. I've tried doing replacing it in stages rather than replacing the whole region but it still seems to shift some. I mean it's not drastic but why does it do this? If it's getting the first one right, why are the rest not the same?
Cheers
Old 05-18-2014, 03:34 PM
The Dougfather The Dougfather is offline
Default Re: Drum Replacer, out of syn
Usual process?
Plugin, tab to transient paste, more info dude!
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 05-19-2014, 01:54 AM
adam_w1 adam_w1 is offline
That's totally normal - it's not you - the software never HAS worked with particular accuracy and is sometimes great, sometimes...not! SR the thing you want to sound replace, then listen to it, and manually edit anything that sounds sketchy or flams with the original source.
Me? I do what the poster above does if I have to..one hit at a time.
Old 05-19-2014, 07:26 AM
jntracks jntracks is offline
Try Steven Slate Trigger. You'll get better results in basically zero time compared to using that old dinosaur sound replacer. fully customizable in real time.
It's so worth the money, just for the basic one, if you're going to be adding your own samples anyway. How much are you hours trying to fight sound replacer worth?
-j
www.jntracks.com
Drum samples for Sound Replacer Blackers The Drum Room 9 02-12-2018 05:06 PM
Is there a drum replacer/sound replacer??? sethbrand General Discussion 2 03-08-2006 08:40 AM
Where do you get your Sound Replacer Drum Sounds? bkremer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 07-21-2005 01:24 PM
Sound Replacer Drum Samples XCLAIM Tips & Tricks 27 03-02-2001 12:26 AM
Drum Sounds for Sound Replacer XCLAIM Tips & Tricks 1 11-14-1999 01:26 AM
