PT session emergency ! Help ,Please !
Can anyone please advise... I'm mid session , just recorded a long solo piano take , computer is frozen with spinning beachball, I can't stop record , can't hit save etc. I'm afraid I'll lose the recording if I do a force quit . Any advice ?? This freezing has happened a couple times today while I was editing and left computer for a break . Using PT HD 9 with no problems but just recently installed Update " 905 Updater 72733 " which was offered as a " critical update " in a pop-up when I opened PT . Thanks in advance for any help. Don't know if the session is still recording .... will it go until the hard drive is full ? Ayyy !
Richard Dworsky |
Re: PT session emergency ! Help ,Please !
Nothing to do but force quit, and, yes, it will lose that one take. When you get it back up, try limiting record time (Preferences/Operation). The "Use All Available Space" option is not generally recommended, despite being the default.
It's possible that the program will have closed the audio file and you can find it and add it to the session. Probably not, but worth a try. If not, be sure to run Disk Utility on the record disk, because it may have messed up the catalog in the process of crashing the program.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
maybe not lost
after force quit try checking the audio files folder and import the latest file |
Thanks David and Barlevy for your help ! I'll try searching the audio folders for the stray files. I finally had to force quit and then just rerecorded the music . Even powering off was tricky cause Pro Tools would stay open for a while after the force quit. Later I had the same crash problem but it was while I was editing , so I don't think it's related to inactivity . Not sure if it's a PT or Mac issue now. Thanks again and best wishes !
Richard Dworsky |
Do you have iZotope Nectar inserted as a plug-in on any track?
Pro Tools, Studio One Pro 2022 Mac Studio M1 Max 64GB-1TB NVME OWC Thunderbay Mini (4TB SSD) OWC Express 4M2 (4 X 2TB) Interface: Presonus Quantum Presonus Faderport & Faderport 8 Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128 BM5A, KRK VXT4, Equator D5 2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig) |
Hey! Where'd my post go?
I hate it when that happens...
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
PT Session Emergency ! Help , Please ! | Rich | Pro Tools TDM Systems (Mac) | 1 | 09-20-2011 02:58 AM |
Emergency help needed please! session back up files are gone for some reason | siga | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-02-2009 09:09 PM |
serious emergency--in session now(grid gone) | jmallen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 10-20-2004 05:22 PM |
To DIGI: spare PT just for emergency edit and tradings session between PT HD and 5.1. | Alécio Costa | Pro Tools TDM Systems (Mac) | 9 | 05-08-2002 11:51 AM |
Emergency: Help needed desperately (problem opening a Pro Tools session) | jampater | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-24-2001 01:00 AM |
