  #31
Old 02-19-2023, 07:30 AM
Arichlsss Arichlsss is offline
Default Re: Hybrid Engine/ DSP Mode latency issue
I’ve got two hdx cards. On a blank sessions if I bring up a blank track to record and have a few aux’s with hadware inserts the delay comensation does not work even though all the aux’s and track are in hybrid mode. Hdx mode works.
Also none of the track misalignment issues we taking a track out of hybrid mode.
It’s a same to have to figure out the features that work and the ones that don’t but that’s life.
Still a great product I’m just saying off of hybrid unless it’s the only way and then I’ll be prepared for the issues.
  #32
Old 03-11-2023, 07:51 PM
Guy McDude Guy McDude is offline
Originally Posted by matt mahaffey View Post
I run dense sessions but have to enable the Hybrid Engine to overdub constantly. As soon as i turn Hybrid off, my audio is misaligned. I have found that if i simply click "Setup" and then "Playback Engine" and close the window having changed nothing..... everything aligns back properly. Talk about a ghost in the machine. Try it instead of relaunching the session, might save you some time!
yes!
this seems to shake things loose, and re shuffles the deck.
terribly maddening when youre working alone, maddening AND embarressing when theres clients there.
Best,
Sean
Sean McDonald
Red Medicine Recording LLC
Sofa King Music Services
http://www.seanmcdonald.com
  #33
Old 03-28-2023, 07:50 AM
tonwurm's Avatar
tonwurm tonwurm is offline
It seems that the latest update (2023.3) made no change to this issue
MP5,1 12core 3.46ghz 96GB
Ultimate HDX
https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ
  #34
Old 03-28-2023, 07:52 AM
Boe Larsen Boe Larsen is offline
Boe Larsen
Producer
www.millfactory.dk
  #35
Old 04-06-2023, 06:30 PM
fsavell fsavell is offline
Not sure if this is the same issue, but sounds similar.
I have blip triggers sending to the side-chain of FF Pro-MB to gate toms. If I run the session in Hybrid mode, everything works great.
If I switch to DSP mode the timing/latency is off and tom trigger sounds terrible. Compensate for side-chains pref is active on both modes.
If I freeze or commit the triggered Tom tracks, its correct. I haven't really noticed latency issues on anything else when using DSP, but it's somewhat of a drag.
Happens on installs of both Monterey and Catalina.
Forrester
Pro Tools Ultimate 2023.12, HDX1 • Mac Studio M2 Ultra - macOS 14.2
  #36
Old 10-09-2023, 11:58 PM
Kaneepa Kaneepa is offline
Avid, please fix all the latency compensation issues in Hybrid Mode.
Whenever I record a new vocal in Hybrid mode, and I have a reverb send (to Revibe II), the playback is always late.
The moment I switch the tracks into native it goes back to normal.
If I deactivate the reverb send on the vocal track, playback is normal.
Please help. This is happening since the beginning of Hybrid engine, with different systems / OS / hardware.
  #37
Old 10-11-2023, 01:28 AM
tonwurm's Avatar
doesn´t occur on my system... Hybrid mode activated, in both DSP mode enabled or disabled and a reverb send to Revibe II, playback is perfect
Ultimate HDX
  #38
Old 10-13-2023, 05:48 AM
It happens to me once you have two or more tracks sending to the DSP reverb. One typically is recording or in input, the other is playing back.. still in DSP mode (green sign on).
  #39
Old 11-07-2023, 08:45 PM
Any Fix Yet?
we are still waiting....
Best,
Sean
Sean McDonald
  #40
Old 11-08-2023, 09:32 AM
XJENSEN XJENSEN is offline
Originally Posted by MCorbin View Post
Yep, what Dominic said... please log a case. Make sure the agent associates it with an ADC bug so we can track and prioritize it.
With all due respect, but I have been filing numerous cases - probably over 20 - in the last 7 years relating to ADC problems alone. All this time, AVID has done absolutely nothing with that information, apart from giving me the big fat finger blaming it on user error.
You cannot believe how much of my time was lost speaking to clueless support agents about this. And now you will take things seriously all of a sudden?
Hybrid Engine vs Non-Hybrid HX|2 in Post. minister Post - Surround - Video 6 12-27-2021 03:41 AM
Hybrid Mixer and HDX - need a separate "mixing" high-latency DSP mode for tracks Skwaidu Pro Tools 2 10-24-2021 08:51 AM
HDX Classic / Hybrid engine low latency bus routing question RobertDorn Pro Tools HDX & HD Native Systems (Mac) 7 09-30-2021 02:11 PM
The Hybrid Engine LDS Pro Tools HDX & HD Native Systems (Mac) 64 07-31-2021 09:17 AM
Low latency mode issue in Pro Tools 10, has it been sort out? Gary Gould Pro Tools 10 6 01-29-2015 05:16 AM
