Crash when bouncing with multiple 24fps video clips [UME-1676]
I have reported to Avid several times, that in sessions with multiple video clips at 24fps on a single timeline will play back fine, but when bouncing to disk with video, will repeatedly crash the video engine after the first bounce. This will result in the need to reboot between each bounce. Very time consuming.
This will happen ONLY when video is 24fps. This is on a Mac Mini M1 with 16GB ram. Super annoying for those of us that do commercial campaigns. Jeffro? Sent from my iPhone using Tapatalk
Joe Tools Re-Recording Mixer/Sound Designer Nova Scotia Canada OS Ventura 13.0 Pro Tools Ultimate 2022.12 Mac Studio Max 32GB Ram OS 10.8.5 Pro Tools HD Accel Version 10.3.8 Mid 2012 Mac Pro 5,1 32GB Ram Last edited by jeffro; 03-23-2022 at 10:48 PM. Reason: Renamed thread from "PT Ultimate 2021.12 Problems Carries Over From Big Sur To Monterey" |
Re: PT Ultimate 2021.12 Problems Carries Over From Big Sur To Monterey
Just curious because I am getting an AVE crash when bouncing to that codec on the same system. |
Yes indeed. H264 .MP4 or .MOV Sent from my iPhone using Tapatalk
Joe Tools Re-Recording Mixer/Sound Designer Nova Scotia Canada OS Ventura 13.0 Pro Tools Ultimate 2022.12 Mac Studio Max 32GB Ram OS 10.8.5 Pro Tools HD Accel Version 10.3.8 Mid 2012 Mac Pro 5,1 32GB Ram |
Yes I did and was sent to Lois at support yesterday. I tried to send it via email, but file was a little large. Lois had me send it via wetransfer and I provided him the link in an email. Just seeing that other email now. Sent from my iPhone using Tapatalk
Re: Crash when bouncing with multiple 24fps video clips
I don’t think it’s specific to just 24fps videos or having multiple videos on the timeline.
I do think this is a bug only with h.264 output, or if the original video is h.264. In the mean time, Ive found a work around is to disable the video engine immediately after 1st bounce. Do not press play or do anything else other than go into the playback engine and disable AVE. Once disabled, re-enable and you should be good to go. You won’t have to relaunch PT after every bounce. Hopefully this will work for you until there is a solution. |
In this regard, I was able to switch to another session with H264 encoded media, the only difference being that it was a different frame rate. No issues whatsoever. Odd.
Also, thank you for the work around. I will give that a shot.
I'm having this same issue - on PT 2021.12.0
Did this ever get fixed? |
I have simply switched to exporting h265 and the problem is solved.
QUESTION: Video in Pro Tools Studio - multiple video clips allowed? | Bigbottomend | Pro Tools | 10 | 06-29-2022 02:22 AM |
Bouncing multiple Clips as separate WAVs? | Peakoverload | Pro Tools | 2 | 05-06-2022 11:00 AM |
Adding multiple video clips in Pro tools | jackson92119 | Tips & Tricks | 3 | 01-03-2015 09:58 PM |
Multiple Video Clips | 19 frets | Pro Tools 11 | 5 | 05-08-2014 10:08 AM |
PT 7.2 and Multiple Video Clips Question | laki | Pro Tools TDM Systems (Mac) | 1 | 08-14-2006 01:23 AM |
