How to sync two audio files PT10HD
Hi there,
I'm sorry, but I can't find answer for this... I have tons of audio files from DSLR and I need to sync them with my ZoomH6 audio... is there any way how to do it without manual sync of every single file? For example in audition CC I just select two files, click on sync and everything is ok... is there any simular way in PT10HD?! Thanks a lot for anything... Last edited by blop; 01-30-2016 at 02:49 AM. |
Re: How to sync two audio files PT10HD
If you do have matching timecode stamped to both the DSLR audio the ZoomH6 audio, then read the field recorder workflow guide for how to do this. If $200 is in your budget, you could purchase PluralEyes and have it automagically sync the audio.
Can you sync playheads in PT10HD and Final Cut? | jkuehlin | Pro Tools 10 | 1 | 03-15-2013 11:21 AM |
usaved PT session saving unsaved audio files to audio files folder | mermermer | Pro Tools HDX & HD Native Systems (Mac) | 1 | 07-18-2012 11:50 AM |
Audio files on one FW Drive render blank audio files when copied | ridmik | Digidesign Hardware & Software | 4 | 03-30-2012 12:55 PM |
Sync Audio - Editor Used Camera Track Only -Waveform Sync? | milosziv | Post - Surround - Video | 7 | 11-30-2011 05:26 AM |
Fade Files as Audio Files in "Missing Audio" ?? | CCash | Pro Tools TDM Systems (Mac) | 6 | 05-18-2005 09:00 AM |
