Old 08-24-2015, 05:32 AM
martinaston martinaston is offline
Default Windows behaviour in PT11.3.1
The transport bar specifically, but other windows (plug-ins, dialogues etc.) all are exhibiting strange behaviour when moved around within pro-tools, i.e they seem to lose focus and disappear behind the main window when moved even at very slow speed.
I have done extensive virus/malware checks but nothing showing up from Avast!, Malwarebytes, Superantispyware. I have also run Winthruster to detect registry errors, system is clean.
The problem only affects pro tools (11.3.1), other apps running on the PC do not malfunction.
Windows 7 Home Premium SP1
Intel Core(TM)2 Quad CPU Q9650 @3.00GHz
8.00GB
64bit
Any remedies Doctor?
Old 08-24-2015, 08:14 AM
Default Re: Windows behaviour in PT11.3.1
well, I'm not a doctor(but I DID stay at a Holiday Inn last night), but with a system this old, it could be lots of things If you have anti-virus on this computer, I would try removing it(and anything else running in the background that does not NEED to be running). It might also be worth opening the case and re-seating every card and connector. Also would check for updated drivers for everything(especially the graphics card)
Old 08-24-2015, 10:07 AM
YYR123's Avatar
YYR123 YYR123 is offline
Yeah your GPU make sure it's up to date and powerful enough
All optimization have been done and windows update is turned off, along with all the automatic scanning of virus/malware in the background
dr
Daniel
Old 08-24-2015, 01:47 PM
aha thanks Doctor Dave, I have updated the graphics drivers but Avast is running, I'll try halting it and anything else that might be conflicting. It is only a recent problem though, the system has always been quite stable,I am running Addictive Drummer 2 live and multiple instances of RAM heavy plug-ins such as Waves Tune but the resources meter in PT is within acceptable limits, so I don't think it is a RAM issue...
I tend to think there is malware somewhere on my system that isn't being picked up by the various Wehrmacht divisions of protection, I just wondered if anyone else had experienced the same symptoms and if so how to zap the infiltrator
Old 08-24-2015, 01:48 PM
Originally Posted by bcwiz View Post
Likely related to the problem of plugins (floating windows) no longer able to sit on top of the video window and command focus toggling off. One of a number of reasons I don't use PT11 or 12 for editing (or mixing for that matter) Doesn't do this on OSX. Tech support was useless so I gave up.
hmmm I reckon you might have nailed it
Old 08-26-2015, 07:27 AM
AudioEngineer591 AudioEngineer591 is offline
Install Windows 10! Problem solved!
AVID Pro Tools 12.2
Windows 10 Pro
Intel i7-4800MQ @3.7GHz
GTX870M 3GB
32GB DDR3L-1600
Old 08-26-2015, 08:57 AM
Is it available already? Is it free?
Old 09-07-2015, 02:17 PM
real_eyes real_eyes is offline
Having a similar problem on OSX and 11.3.1. Started a post the other day about it and got no answers, and then saw this thread so it's good to know I'm not completely alone. It's definitely driving me bonkers trying to edit with any flow. Any pop up/dialogue window/audiosuite render takes the focus off my edit window and I have to select somewhere on it to get focus back and move on with editing.
Really hating that nothing can sit on top of the video window too.
Maybe 11.3.2 would fix this...too bad I have to buy PT12 to get it.
I have a dream that one day Avid will upgrade Pro Tools Markers tracks.....
Old 09-14-2015, 01:26 PM
Does this fix the inability of PT11 and 12 to have floating windows (plugins) on top of the video window?
Yes it fixes all issues. I am running it with no problems!
AVID Pro Tools 12.2
Windows 10 Pro
GTX870M 3GB
32GB DDR3L-1600
Old 09-14-2015, 03:51 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
Windows 8 solved a lot of that kind of stuff for me.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Erratic behaviour of Mbox 2 Pro with PT11 nyjdams Pro Tools 11 0 12-22-2014 06:14 AM
Strange Fade Behaviour in PT11 Mischdepp macOS 2 07-29-2014 11:49 AM
PT11-Disk Allocation Behaviour? VRW Tips & Tricks 1 02-08-2014 07:34 AM
Spectrasonics strange behaviour PT11.1.1 JimmyM Virtual Instruments 1 01-19-2014 10:29 AM
Did Avid "Fix" the Floating windows problem in PT11 under Windows? M-ManLA Pro Tools 11 10 07-08-2013 03:07 PM
