Annoying playback behaviour
Since PT9 (and sometimes also in PT8 but never in 7 and before) playback is not smooth if you simply "cut" a region with command-e (separate region command. With nothing moved around the separate region command should do nothing on playback behaviour - but it does. It's the same with processing audio suite plugins, btw. But I don't want to start the next discussion about incompatible plugins…
PT is loosing quality from update to update and users have to pay money from update to update - something is going into the wrong direction!
Mac Pro 5,1 12 Core 3,46 GHz MacOs 10.15.7 (Catalina/Dosdude), 64GB Ram, Angelbird Wings x2, PT HDX, HD I/O, 2x 192i/o, 1x Digi Pre, 1x Red8Pre 2x Avid S1. Artist Transport, PT2021.6 http://www.4tune.at |
Re: Annoying playback behaviour
Figured this problem out to 88,2kHz sessions.
Doesn't seem to appear at 44,1kHz… Avid, when will you pay attention to this problem?
Anybody working on 88,1kHz?
Am I alone?
Hint!: Set a long post-roll time to avoid annoying playback stops! | EricWillhelm | Tips & Tricks | 4 | 07-01-2013 05:11 PM |
Annoying Playback Issues | 12stepcornelius | macOS | 4 | 10-24-2012 01:53 PM |
Annoying midi playback error | Herokazz | Windows | 1 | 04-04-2012 03:59 PM |
"save as" and other dialogues - annoying behaviour | fm_xtk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 06-23-2010 12:49 PM |
'Write to All' in playback behaviour | thermisonic | Post - Surround - Video | 3 | 03-24-2010 07:53 AM |
