Old 05-01-2002, 11:56 PM
Peterjk's Avatar
Peterjk Peterjk is offline
Default The Ghost of 5.0.1
Hi Guys....
Riddle me this: A friend of mine (once) had PT 5.0.1 instaled but is now using 5.1.1 - BUT once in a while (when he doubleclicks on the session files) his MAC wil start up 5.0.1 and NOT 5.1.1.
I thought I could solve the problem by simply removing his copy of 5.0.1 BUT THERE IS NONE. Not even after I removed the 5.0.1 preferences the problem seems to go away. It is only "attached" to certain session files, but will occur everytime on those specific files.
Hm.....? Anyone?
Peter
[img]images/icons/confused.gif[/img]
Old 05-02-2002, 07:10 AM
DigiTechSupt's Avatar
Default Re: The Ghost of 5.0.1
-Does PT 5.0.1 actually launch or does the Mac OS report a "could not open file because PT 5.0.1 could not be found" error?
If the former, then there is a lingering copy of the PT 5.0.1 application on one of the drives connected to the system...hunt it down and remove it. (since a PT 5.0.1 preference file is created, this is most likely the case)
-If the latter, I would suggest rebuilding the Desktop file for all drives.
Brent
Avid Audio Tech Support
Support FAQ
Old 05-03-2002, 01:19 AM
Peterjk's Avatar
The session is launching completely. And I already tried to hunt it down and delete it. But it was nowhere to be found. Maybe I should try again.
Peter
Old 05-03-2002, 09:14 AM
putney2 putney2 is offline
Obsolete Digi folder maybe ??????
-russell, OPA
Old 05-04-2002, 12:37 AM
Mark Haliday Mark Haliday is offline
do a sherlock search on "DAE" : as Russel said you may have several copies of this. There should only be one DAE app. on your disk
Another reason may be that the PT app. file was
renamed
Try searching for all applications on your disks and see if the PT icon shows up somwhere...
Good luck...
Ghost for Mac plugset 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-12-2006 09:04 AM
norton ghost 9.0 kinetic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 10-13-2004 07:56 PM
Norton ghost neatguys 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-19-2004 06:58 PM
Norton Ghost [OT] Steve Moore 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 11-11-2003 03:03 PM
Still got a ghost terrydrums General Discussion 4 04-23-2002 11:58 AM
