Old 11-01-2022, 05:42 AM
kaonashi kaonashi is offline
Default HDX on mac Studio 2022.10
Hello,
Running two separate of mac studios with thunderbolt HDX chassis and getting the same error message inconsistently when booting pro tools.
Unable to find an Audio Interface attached to the first HDX card. Please check the power and digilink cables and click ok to rescan. Cancel to open the Playback Engine Dialog and select a different device.
PT Version 2022.10
Mac Studio (2022)
M1 Ultra
128GB RAM
I've found an inconsistent workaround which is to either quit and relaunch pro tools / change the playback engine or switch the number of voices from HDX 1 to HDX 3 can kick it in and it sees the 3 HDX cards.
Has anyone else seen this and have any idea what might be causing it? Thanks
Old 11-01-2022, 06:08 AM
its2loud its2loud is online now
Default Re: HDX on mac Studio 2022.10
There are so many threads about Mac Studio having issues with thunderbolt chassis and HDX.
One of the most common solutions is to have the chassis plug into a Thunderbolt Dock and not directly into the Mac.
Feel free to search the forums
Old 11-01-2022, 08:00 AM
glasswing glasswing is offline
I haven't had any problems yet. I use the Avid Thunderbolt Chassis (one card). Plugged directly in to the Mac Studio.
Mac Studio Ultra / 128 RAM/2TB HD / Avid HDX Chassis / 2 X Sonnet Echo Dual NVMe Thunderbolt Docks w Samsung 970 EVO Plus (6TB) / Avid C24 / Avid 16X16 I/O Analog / Lynx Aurora 16/16 1/O Analog / Dangerous 2 Bus / Benchmark ADC1
www.glasswing.com
www.richardsales.com
Old 11-01-2022, 02:17 PM
Peter Duemmler Peter Duemmler is offline
Same here. No problems at all.
http://www.merlinsound.de
Old 11-04-2022, 01:26 PM
darcey darcey is offline
I had the similar kind of issue which I was able to resolve by having the chassis plug into a Thunderbolt Dock.
Old 11-07-2022, 04:46 AM
Thanks for your reply, information on this is harder to find than you suggest but thanks anyways for your recommendation on the Thunderbolt Dock, which dock are you using specifically?
Old 11-18-2022, 02:50 PM
lancemcv's Avatar
lancemcv lancemcv is offline
Try booting the Mac Studio without the thunderbolt chassis plugged in then turn it on and plug it in, if it still gets the error then reboot with it still attached and see if that works. Sometimes the thunderbolt ports need to be woken up. If it still doesn't work try a pram reset with the chassis turned on and attached that may do the trick.
Mac Pro 5,1 12 core 3.46ghz
OS X 12.6.1
Opencore 0.8.6
Pro Tools Ultimate 2022.10
Mac Pro 2009 upgraded to 5,1 12 core 3.46ghz
GPU RX6800XT, Samsung 970 EVO Plus pcie boot drive, Titan Ridge flashed for Mac.
Midas M32r console. iPad Pro with Avid Control
Old 11-19-2022, 04:19 PM
Branko's Avatar
Branko Branko is offline
The dock solution works. I used OWC Thunderbolt Hub for my Mac Mini M1 and it solved the problem
Branko Neskov c.a.s.
www.loudness-films.pt
Pro Tools 2022.4 on Mac Studio M1 Ultra Selle Sellink Pro Tools 44 06-02-2023 09:30 AM
Pro Tools Studio 2022.9 problems. Please help me Simonluka Pro Tools 16 10-20-2022 09:52 AM
Graphic inconsistencies PT Studio 2022.7 ChrisRR Pro Tools 0 09-13-2022 06:32 PM
Install Issue W10 & PT Studio 2022 nymills Windows 12 09-09-2022 02:24 PM
PT 2022 Studio with MBP mid 2012 NeoAle73 Getting Started 0 04-27-2022 12:27 AM
