Old 10-11-2024, 05:28 AM
voicycle voicycle is offline
Default Audient Loopback - paid versions only?
I was about to raise a ticket with Audient to troubleshoot the lack of audio from the ch11-12 system audio loopback feature in my iD14 mkII, but then suddenly wondered if it's actually a limitation of the free version of ProTools?
I'm sure I successfully demo'ed the feature at some point a few years ago by test recording some audio from a Zoom session into ProTools, but as it is now I'm not able to get any signal into ProTools from those two channels. I can't say for sure, but I think I probably had a paid subsciption version of ProTools at that time. Sometime after they moved to the current product tiers and replaced First with Intro I cancelled my sub and downgraded to Intro. As a VO artist I don't really need more than 4 tracks so it has worked pretty well for me so far. And loopback isn't mission critical for me so it's been low priority to troubleshoot. I genuinely don't know how the timeline stacks up in terms of the when I had loopback functioning successfully and the end of my subsciption though so it's very much an 'I wonder if...'
I note that in the version comparison chart for ProTools it says "Aux I/O inputs and outputs - N/A" for the intro version and a minimum of 4/4 for all the rest. Is that what my problem is here, or do I need to go investigate with Audient?
Screenshot of a test setup included for reference - Spotify (just because it was open) is playing successfully to the iD14's "DAW 1-2" and the audio is coming through fine on the monitors. iD app has DAW 1-2 selected as the loopback source. ProTools track 'Audio 2' has Loopback 1-2 selected as the inputs and is record enabled, but there's no signal tickling the meters for that track.
In the same session I can record enable a mic as normal and see the meter showing signal, so it seems like the issue is either with the interface routing the outs to the loopback ins, or with the way the inputs are coming into ProTools.
Any obvious signs to tell me whether the culprit is Avid or Audient?
Thanks!
Old 10-11-2024, 07:36 AM
its2loud its2loud is offline
Default Re: Audient Loopback - paid versions only?
Yes, this is the issue due to the limitations of Pro Tools Intro.
Old 10-11-2024, 11:30 AM
The Weed's Avatar
The Weed The Weed is offline
You get 8 Tracks, but only 4 simultaneous Recording Inputs. You do get 4 Aux Input Tracks, but not Aux I/O (which is similar to Loopback).
Pro Tools Comparison.
Take your projects to the next level with a non-union national read at reasonable rates
Demos: brucehayward dot com
SonoBus | Source-Connect: brucehayward | Options for Remote Direction
Old 10-12-2024, 09:32 AM
Thanks - I would have initially assumed that Aux I/O is a Pro Tools software version of loopback and that if the interface is doing loopback at a hardware level then Pro Tools should see the inputs as bog standard Auxes rather than anything it knows to be "I/O".
What exactly is the difference between the two as far as PT is concerned?
Help..Not Getting Loopback.. tomhartman MBOX Studio 4 05-19-2023 08:50 AM
Loopback hrbaltzer MBOX Studio 2 02-24-2023 03:05 AM
Audient ASP880 in Audient ID14MKII ADAT Weak Signal cj_Db Third Party Interfaces 12 07-07-2021 06:26 PM
Paid for (paid monthly) download, Avid canceled it several days later.. av1990 Licensing & Accounts 0 05-08-2020 09:14 AM
What is loopback? Popmeise Third Party Interfaces 4 12-15-2017 01:32 PM
