Pro Tools outputs loud midi when starting recording
Anyone else experience this?
Latest version of Pro Tools Studio, Version: 2022.10.0 Focusrite 18i20 (2nd Gen), Firmware: 1653, Driver: 4.102.4 Superior 3.0 - Stereo Inst Track Windows 10 Pro. Arm mono audio track (bass gtr). 2 bar count in. When it gets to the insert point I get full velocity midi notes from Superior when it starts recording. I've checked my midi notes in the Instr track, I get a full velocity kick, snare and cymbal. There's not even a cymbal programmed in the midi. I also tried muting the midi section so there is no trigger with same result. POW! During Playback it's fine. Only when arming/rec a track? I have the latest Focusrite Control and Driver installed. This is driving me nuts. I can't even record because the loud midi, screws up the click as well. |
Re: Pro Tools outputs loud midi when starting recording
Hmmm, SD3 and recording audio tracks works fine here. My 2 suggestions:
1-double-check your routing 2-commit the instrument track and disable it(but do not hide). That should solve the problem so you can record your other parts. If you need to make midi changes later, just enable the instrument track and mute(or delete) the "commit" track
Do you have some stray hidden tracks that were not made inactive?
Recording Multiple MIDI Outputs Simultaneously | adam79 | Virtual Instruments | 8 | 06-16-2017 04:31 AM |
Loud clicks when starting or stopping playback | tnipe | Windows | 36 | 06-10-2016 11:58 AM |
Digi 003 Loud Outputs | Jesslisten | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-25-2014 03:02 PM |
HELP PLEASE - Loud crack/pop when starting | kidbazooka | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 04-15-2009 10:19 AM |
Loud Pops at edits(punch points), starting and stopping play | dw_deej | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 12-10-2007 03:57 PM |
