#21
Re: Macbook Pro for Pro Tools Ultimate
Yep Butterfly, so just check it carefully.
#22
I sure will, thanks for the heads up.
#23
We had/have some of those 15.1 MBP. Plenty capable machine. In most instances we're swapping them out for M1 MacBook Airs. Pro Tools is usually quite a bit behind supporting the current MacOS version. You won't have an issue with those size sessions.
What happens in Vegas, we make happen... |
#24
Update: The 2018 Macbook Pro deal fell through, so I got a 15" 2019 Macbook Pro with the i9 and 32GB RAM. I'll get it in a few days.
#25
2019 i9 Macbook Pro arrived. Very speedy, brand new battery with 0 cycles. I'll be installing software over the new few days, but Harrison Mixbus runs fantastic.
#26
I can confirm the 2019 Macbook Pro i9 w/ 32G RAM and Mojave runs Pro Tools Ultimate 2022.7 amazingly. I have 32 audio tracks with an Orion USB, 16 buses, plus master running on this session. There's the SSL Channel Strip 2 on every track, plus plugins on the buses and master, and HEAT, and I'm at less than 10% CPU.
I'm running SSL 360 app, Decibel wifi to my tablet for metering, and a Presonus Faderport 16, with an HDMI TV for a larger second screen, and it all runs very fast and smooth. I'm happy with the setup. Low buffer of 64 for tracking, 1024 for mixing. I was considering picking up a chassis for my HDX card, but so far, I don't think I'll need it. Besides, to run the playback engine in HDX I assume would need a compatible interface, and this Orion does not have the AVID connections. |
#27
Yes HDX requires DigiLink IO connected to it.
Dumb question - Can I run PT Ultimate on a Macbook Pro? | innerbooty | Pro Tools | 14 | 06-24-2022 07:21 AM |
Video Playback Question - PT Ultimate 2022 on MacBook Pro M1 Pro/Max | sheinke | Post - Surround - Video | 2 | 06-15-2022 05:35 AM |
Pro Tools Ultimate / Pro Tools perpetual license renewal coming up soon... | Justin1524 | Pro Tools | 1 | 06-21-2021 05:43 PM |
Pro Tools Standard->Pro Tools Ultimate Cross-grade clarifications. | Akiz | Licensing & Accounts | 8 | 08-30-2019 10:34 AM |
Ultimate portable solution? macbook pro vs. air | tonejunkee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 17 | 01-03-2011 12:22 AM |
