Old 06-09-2003, 05:02 PM
roryrok roryrok is offline
Default DIGI002 ADAT inputs - 96k?
ok so ive read adat lightpipes cant exceed 48k sampling rates, so does this mean that digi002 can only record up to 96k on the 8 analog ins and the spdif? can it even record 4 channels through the lightpipe at 96k like some A/D converters do now? whats the deal?
Old 06-09-2003, 07:16 PM
Duardo Duardo is offline
Default Re: DIGI002 ADAT inputs - 96k?
No, it can't record at 96kHz through the optical inputs. Not sure why they didn't at least let it do four channels, but they didn't...
-Duardo
Old 06-09-2003, 07:39 PM
valvebrother valvebrother is offline
To do 4 channels of 96 kHz over a single lightpipe connection still requires SMUX.
Someone posted a link the other day on this topic and suggested that SMUX could have had a licensing issue that Digi didn't want to mess with. Im guessing it has as much to do with encouraging us to drop the cash for an HD system, but, then again Im pretty cynical!
[img]images/icons/smile.gif[/img]
Damon
Old 06-09-2003, 11:29 PM
damonmenne damonmenne is offline
Damon
<font size="2" face="Verdana, Arial">Gah! Another Damon! Die clone! ;-]
Old 06-10-2003, 02:38 PM
Wow! That is indeed a rare thing. Im sure there is some sort of quota on us.
Old 06-10-2003, 06:41 PM
DigiTechSupt's Avatar
Just to be clear, you can record 96kHz at the optical inputs, but only when
optical format = SPDIF
RCA = OFF
in the HW setup window.
Best to all,
MikeZ
Digidesign Technical Support
Avid Audio Tech Support
Support FAQ
Old 08-16-2014, 02:57 AM
Kudy Kudy is offline
I've read that the 002 is limited to '2 Channels at 96khz'. Is this right?
I want to connect an OctoPre and record 8 channels at 96khz with the 002R.
Will it work?
Thanks in advance.
Old 08-16-2014, 11:05 AM
Craig F Craig F is offline
Originally Posted by Kudy View Post
Will it work?
Thanks in advance.
no
you can if you use the 002's ADC but not through Light Pipe (44.1/48 only)
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
HELP! using 8 inputs on Digi002? bustedacres Getting Started 12 10-27-2013 10:29 AM
Why only 2 inputs on my Digi002? wfenlon macOS 11 05-06-2012 02:07 PM
Digi002 XLR inputs strictly mic? kirkbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-18-2009 10:57 PM
Digi002 Rack - send analog inputs through ADAT out? copperpipe General Discussion 2 06-05-2007 05:57 PM
ADAT for additional inputs for Digi002??? CraigD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-21-2004 04:33 PM
