Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2021
Old 10-14-2021, 07:44 AM
bernstudios bernstudios is offline
Default Waves and M1
hey guys
its seems like the only way to get my waves working on a Mac mini M1 is to use protools 2021.7 in rosetta mode is that right? how do you guys use your waves plugins on M1 machines?
thx for the help
Old 10-14-2021, 08:16 AM
JFreak's Avatar
JFreak JFreak is online now
Default Re: Waves and M1
I thought WavesHell was just updated to V13 that supports Apple Silicon natively..?
Janne
its2loud its2loud is offline
Originally Posted by bernstudios View Post
hey guys
thx for the help
Pro Tools can only run under Rosetta 2 currently on the M1 chip. There is no M1 native version of Pro Tools yet.
Waves just released v13 plugins with native support for M1 but Pro Tools is not listed as a supported DAW in Native mode. V12 & v13 will work under Rosetta 2.
Old 10-14-2021, 08:57 AM
So if I'm am interpreting this correctly, Waves released a new V13 with M1 native support, however to be able to run Waves plugins natively on an M1 Mac, it must be running a DAW also with native M1 support. Since Protools is still not native M1 compatible (only M1 compatible via Rosetta 2), it will not host native M1 Waves plugins and only run the Intel based plugins via Rosetta 2. If you use Apple Logic (I assume it is M1 native now, no?) and Waves v13 M1 native, it would run together as M1 native. Does anyone know which DAWs are M1 native currently? (Presonus S1, Steinberg Nuendo or Cubase, MOTU Digital Performer, Universal Audio Luna, etc.)
Obsidian Dragon
MacBookPro14,3 - Intel Core i7 3.1 GHz, 16 GB
MacOS 11.6 running Protools 2021.10
Old 10-14-2021, 09:07 AM
ok and how can I use protools under rosetta 2? I`m completely new to the M1 world..
Old 10-14-2021, 09:09 AM
JFreak's Avatar
Working just fine here, just install and run. If you have plugin problems, move plugins to unused folder and try again.
Janne
Old 10-14-2021, 10:44 AM
massivekerry massivekerry is offline
Also remember that Waves (now) uses a proprietary copy-protection system. Pro Tools (and lots of other pro audio software) still use PACE iLok for copy-protection, which has not released an Apple Silicon Native version of their software. There's at least one article on Pro Tools Expert pointing out that "whenever" some developers might be ready to have Silicon-Native versions of their software ready, you're not going to see any real positive movement forward until PACE re-tools their copy-protection.
Kerry Smith
http://apothekerry.com
12-core 3.46GHz Cheese Grater, 64GB RAM, HD | Native, HD I/O
Old 10-14-2021, 10:49 AM
JFreak's Avatar
... and PACE likely releases their Apple Silicon native software right after Avid releases Apple Silicon PT.
Janne
Old 10-14-2021, 10:56 AM
again HOW can I use protools under rosetta 2? when I startup my protools system on my M1 its DOESN`T startup with rosetta!
Old 10-14-2021, 11:31 AM
Rosetta is automatically running if the Mac receives Intel instructions. It is an Intel emulator that runs behind the scenes on a M1 Mac. Just load Protools as if you are on an Intel Mac and it will run. Rosetta2 is pretty seamless and works very well. You just won't see the performance that the M1 is capable of.
Obsidian Dragon
Pro Tools missing V9 plugins from Waves after updating Waves Central williamg AAX Plug-ins 4 12-14-2019 06:54 AM
FS: Waves Kramer Master Tape and other Waves plugins MatthieuH Buy & Sell 0 05-16-2016 09:57 AM
Not enough space on Waves only ilok to download Waves update 7 crizdee Pro Tools TDM Systems (Mac) 38 11-09-2009 06:19 PM
Plugs Advice: Sony vs Waves - Sonalksis vs Waves? John J. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-08-2005 02:31 PM
WAVES Protools7 update and Waves tech support x9blade 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 11-11-2005 07:24 PM
