Old 10-07-2021, 01:53 AM
LukeHoward LukeHoward is offline
Default Re: Dolby Atmos ADM sync issues
Originally Posted by Dax Productions View Post
I think I solved my issue by just adding some time at the beginning of the print and then truncating it manually by inputting the desired timecode in/out when exporting the ADM wav from the renderer.
You can also export ADM files directly from Bounce to Disk in Pro Tools now, in case that's an alternate workflow that works for you.
https://lukehoward.com/
Old 10-07-2021, 06:17 AM
its2loud its2loud is offline
I'm recording into the Renderer. I have the stereo master in my session as a reference. So I'll select that to set the length of the .atmos print and arm the renderer and play down the song. But the timecode of the resulting print always misses the first frame, and adds extra frames at the end.
Using Production Suite 3.7 and PT 2021.6
Appreciate everyone's input. Definitely have learned a ton about the renderer on this job!!
This was your problem. The Render wants at least one second of pre roll before going into record. You’d be better off setting the in and out points in the Renderer and pre rolling Pro Tools into the IN point. Also, you cannot start your project exactly at 00:00:00:00. The Renderer will not wrap around TC prior to 00:00:00:00. Therefore, if your song start is at 00:00:00:00 the Renderer record will be delayed. Move the Pro Tools session later and then change the start TC in the Renderer after you’ve recorded in.
Alternatively, do an offline bounce of your ADM file in Pro Tools like I mentioned earlier and then import that ADM file into the Renderer to create your .Atmos files.
Old 10-08-2021, 09:48 AM
Dax Productions Dax Productions is offline
Thankyou!!! For album #2 in my queue I tried this method and it works WAY better.
HTML code is On
Is there a way to use a 7.2.4 Dolby Atmos home theater as a Pro Tools Dolby Atmos mix Focuret Pro Tools HDX & HD Native Systems (Mac) 19 09-14-2021 08:52 AM
Major Delay Compensation issues with Dolby Atmos Production Suite Mixchump Post - Surround - Video 5 03-15-2021 01:43 PM
Dolby Atmos Production Suite (DAPS) bus/bed automation sync issues jamesa5454 Post - Surround - Video 0 03-21-2020 03:29 AM
Dolby Atmos with S5 MC-Pro critictalk Post - Surround - Video 4 01-01-2018 08:21 AM
Dolby Atmos - Do I need SRC? budster Post - Surround - Video 4 03-24-2015 10:25 AM
