Old 06-18-2005, 09:41 AM
sebamars sebamars is offline
Default Digi 002 sync problem (I need Digi assistance!)
HI, I'm having a problem trying to synchronize a 002 Rack with a Panasonic VHS.
The only way I figured it is to send LTC from the VHS to a Tascam DA 78, then using the DA 78 as a converter, to connect from the DA 78 MIDI OUT port to the MIDI IN on the 002.
I put the PT online, press "play" on the VHS and nothing happens. The MIDI in led on the 002 shows activity, but the cursor line on the edit window goes back and forth erratically.
Any advice would be appreciated.
Thanks in advance.
Sebastian
PT 002 Rack / Mac G5 1.8 / 1gb ram
Old 06-18-2005, 03:18 PM
Default Re: Digi 002 sync problem (I need Digi assistance!)
Check your Peripherals settngs for syncronization.. then check your Session Setup Window for the session start time and to monitor incoming SMPTE.
BTW without locking the clocks -- you won't have synch... you'll have SMPTE trigger.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Rosetta 800 + Digi 002 Problem Clock Sync knudtsy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-22-2010 06:34 PM
assistance needed with digi 002 rack!!!!!!! liilo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-11-2007 08:03 PM
Sync I/O problem with Accel card...DIGI PLEASE !!! Aquarius Pro Tools TDM Systems (Mac) 1 02-10-2004 03:16 PM
Need assistance with T-Racks & Digi 001 please elijahsongs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-06-2002 05:23 AM
DIGI & Studio Vision Pro 4.5.1 sync problem soren 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-10-2000 01:59 AM
