How far is your computer from your control room?
How far is your ProTools computer from your control room or work area?
I am just wondering where everyone puts their noisy computer beasts. I was killing myself comparing loudness specs of computer case fans, CPU coolers and power supplies, etc., when I had a mighty brainstorm: Just put the darn computer in the far bedroom closet and run 50' cables into my control room!!!! That way I can put in the heavy duty fans and not worry about the noise or the cooling. I figure I could get the following: - 50' Digilink cable - 3 16' USB active extension cables for a keyboard or 2 25' Din Cables - 3 16' USB active extension cables for a mouse or 2 25' Din Cables - 2 50' VGA cables (one for each monitor) - 50' Ethernet cable for a Control 24 Am I missing anything? Has anyone tried it? I have never used Protools before so I have no idea what's involved. This not a commercial installation, so I can always walk to the other room to burn CD's or even run 3 15' firewire extensions to an external burner. A quiet control room is very important because I record almost everything except drums in there. |
Re: How far is your computer from your control room?
- 3 16' USB active extension cables for a mouse or 2 25' Din Cables< Get one of these intead: http://www.cyberguys.com/templates/s...search=&child= They work great.
Mark Ettel C.A.S. |
Thanks, filmixer, for your endorsement of that unit.
I did see that on Cyberguys but I dismissed it out of hand because it does not provide USB power, it only works with self powered USB units like printers, scanners and stuff. But your link got me thinking that maybe if I connect it to a externally powered USB hub, then I could power the keyboard and the mouse. How do you use it? |
I have plugged in a keyboard and mouse directly and they work fine. I currently have it feeding a Dell 1905fp's built in hub with the keyboard plugged into that.
Mark Ettel C.A.S. |
"... maybe if I connect it to a externally powered USB hub, then I could power the keyboard and the mouse..."
I thought the same, but call them and ask to make sure (EG, I think an optical mouse does need some power). I have been sucessfully running 50 feet away for years by using a mouse and keyboard on a pair of 2 25' Din Cables, and monitor on 2 25' VGA cables, never noticed any problem. I also have a Logitech USB optical mouse that came with a USB to PS2 adapter, and that seemed to work fine, also.
steve Your Heaven |
Euphonix MC Control V2 - Control room knob PT9HD-HELP | hugoleitao | Artist Series | 3 | 06-09-2012 06:03 PM |
computer in other room...how long can cords be? | guy.fi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 05-31-2007 09:53 AM |
How can I put the computer and hard drives in a machine room. | rodrigal | Pro Tools TDM Systems (Mac) | 6 | 08-27-2001 03:46 AM |
Planning machine room for noisey computer / bit 3, advice please | Tips & Tricks | 16 | 07-16-2000 03:12 PM | |
How Do You Configure Control Room Vol. Control | MeltMediaMusic | Pro Tools TDM Systems (Mac) | 1 | 05-09-2000 10:07 PM |
