Old 07-19-2022, 01:01 AM
kol12 kol12 is offline
Default AUX fader - plugin effect level vs volume level?
How do I make an AUX fader control the mix level of a plugin effect (like reverb)? I have two tracks routed to an AUX track with a reverb insert but the AUX fader controls the volume level of the tracks rather than the amount of reverb effect.
Old 07-19-2022, 01:05 AM
danyg danyg is offline
Default Re: AUX fader - plugin effect level vs volume level?
you have to automate the plugin not the send fader.
Google for "plugin parameter automation"
Mac Studio - Ventura- 64 Gb ram - SSD int 2T - SSD ext 4T - Antelope Galaxy 32
Old 07-19-2022, 01:30 AM
I don't think it is automation, the fader of the AUX track controls the level of reverb effect when I move the fader up or down... Have a look at this screenshot..
https://www.mediafire.com/view/5sfji...b_AUX.jpg/file
Edit: Maybe the reverb is pre fader?
cwsand's Avatar
cwsand cwsand is offline
Typically you would create Sends on the audio tracks that are bussed to the plugin's aux track Input. With a plugin like a Reverb, you would then make it 100% Wet and you could then control the balance between the original source track(s) that are dry and the reverb with the mixer faders. There are other ways to set it up, but that's probably the most common way that gives you the most control. Of course the send levels will also affect the amount of reverb.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (3)
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 07-19-2022, 01:42 AM
cwsand's Avatar
Maybe a screenshot of the Send fader and reverb plugin window would be helpful. Not totally sure what's happening from your description, but if you're not hearing any reverb but the levels of the tracks go up when you move the aux fader, then there may be something in the reverb plugin not set correctly, like making sure it's at 100% Wet.
There's also a Pre/Post fader setting to consider. By default, sends are set to Post Fader meaning that the level on the source track's fader will affect the level going to the send's output - the aux track/reverb. Selecting PRE on the send's fader will send a constant level to the send's output so that moving the source track's fader won't affect the level sent to the send's output (aux track/reverb). It can all be automated as well.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (3)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
Old 07-19-2022, 01:47 AM
cwsand's Avatar
I'm confused because these seem to be contradicting.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (3)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
Old 07-19-2022, 01:52 AM
I think this is what I'm trying to do: https://www.protoolstraining.com/blo...pro-tools.html
You are right, the audio tracks need to have sends to a bus with the reverb. I kind of have it working now. The AUX fader is controlling the dry/wet of the reverb (instead of volume). However I'm hardly hearing any reverb effect...
Old 07-19-2022, 02:09 AM
OK I've got it working :) However selecting PRE on the fader doesn't seem to do anything...
Old 07-19-2022, 08:49 AM
albee1952 albee1952 is online now
If the track's main fader is near -0, then changing between PRE and POST is not likely to be audible. But, Pre on the send fader is different, and whether you hear the difference is a matter of what else is happening. Consider: a vocal track(feeding the main outputs) with a send feeding an aux track with a reverb plugin. If the send is Pre-fader, it will send the same amount to the reverb, no matter where you set the vocal track's main fader. With the send in Post-fade, when you move the vocal track's main fader up or down, the amount sent to the reverb will also go up or down. Post-fade means the send is taking the signal AFTER the track's main fader. Pre-fade means the send takes the signal BEFORE the track's main fader.
Old 07-19-2022, 12:38 PM
cwsand's Avatar
Yeah that's pretty much what I was describing in setting it up.
Getting more reverb really has to do with the gain staging of the send and aux track - if the track level is low, you'll need to turn the fader on the send up. Again, make sure the plugin is 100% wet. You can also place another plugin like a Trim before or after the reverb plugin to send more signal to the reverb or turn the reverb up after processing.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (3)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
HDX Input Monitoring level changes to previous fader level when disengaged ArtyMorty Pro Tools 12 4 09-29-2015 09:21 AM
Texting in volume level of fader.... Nathan W. Pro Tools TDM Systems (Mac) 2 02-15-2015 04:51 PM
Output Level - effect on tone dmock66 Eleven Rack 13 09-22-2011 09:32 PM
How do I pump up the volume/level of my session without clipping master fader ? chrisdee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 25 03-28-2010 01:11 AM
Great free fader plugin with seperate stereo level crizdee Pro Tools TDM Systems (Mac) 0 01-11-2007 03:00 PM
