Old 06-13-2022, 08:47 PM
kol12 kol12 is offline
Default Track height shortcut
Normally when I select the clip on a track and press the E key it expands the track to a medium track height. That key is no longer working. Could I have disabled it somewhere?
Old 06-13-2022, 09:11 PM
HurtMesaMusic's Avatar
HurtMesaMusic HurtMesaMusic is offline
Default Re: Track height shortcut
Is the AZ button highlighted in the upper right corner? That enables that (and many other) shortcut.
Old 06-14-2022, 04:17 AM
That was it, it became un-highlighted somehow. I'll have to look into what else the AZ button does. Thanks...
Old 06-14-2022, 06:02 AM
This is an older article, but gives a great overview.
https://www.soundonsound.com/techniq...commands-focus
Old 06-15-2022, 02:34 AM
Thanks.
Old 06-15-2022, 05:29 AM
Stephen Bond's Avatar
Stephen Bond Stephen Bond is offline
Likely needs updating but a very good resource none the same.
http://www.protoolskeyboardshortcuts.com/
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
is there is a shortcut to make ALL the tracks always a specific height? Zak7 macOS 8 09-11-2018 12:41 PM
Track Height Shortcut Ken Skoglund macOS 0 03-07-2018 06:16 AM
Track height shortcut harrynilsson macOS 13 11-16-2016 03:06 AM
Track Height Shortcut broken cowrange 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 03-04-2012 11:01 AM
shortcut for multi-track height in 7.1? Ken P 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-17-2006 12:53 PM
