How to increase an horizontal line of the automation without involving close nodes
I can't figure out how i can simply increase that low horizontal line of the automation. If I use the tools in the image I get also the upper nodes (the ones in the circles) raised
MUSICNET STUDIO Via Puini, 97 57128 Livorno ITALY |
Re: How to increase an horizontal line of the automation without involving close node
I'm not getting that behavior here.
Just tested Volume and Level Trim and Send Trim. Is that a simple Volume Trim line we're looking at? Perhaps try again in a clean session with a blank audio track. |
If the lower line is truly horizontal, it should only move the line between the break points.
However, if there is a discrepancy in level between the 2 lower points (e.g. one is -12.0dB and the other is -12.1dB, Pro Tools will create new break points at clip boundaries (in case the automation is on top of a clip) or pull the whole automation lane up/down (if there isn’t). (If all break points are within an edit selection, new break points will be created at the selection in/out points instead of clip boundaries.) |
If you don't want the new break points to be created at the selection, hold down option while dragging
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Create horizontal automation line | Sir Hannes | Getting Started | 7 | 04-03-2018 05:42 AM |
Moving two automation nodes at the same time | Antiphones | Pro Tools 12 | 6 | 06-06-2016 10:26 PM |
Somethings changed writing automation nodes! | crizdee | macOS | 1 | 03-19-2012 04:18 PM |
Automation nodes randomly when selecting | marrap | Pro Tools TDM Systems (Mac) | 0 | 05-31-2011 11:26 AM |
Nodes created in automation when using Nudge | alistatic | Pro Tools TDM Systems (Mac) | 1 | 09-24-2007 12:12 PM |
