Old 03-21-2012, 04:54 PM
cwholden cwholden is offline
Default PT Slow Launch and hangup on Peripherals...
PT8.1.1
HD2
x1 192 IO
x3 192Digital
Apogee Big Ben
Mac 2 x 2.8gHz quad-core xeon
18GBRAM
OSX10.6.7
Waves Diamond v8
Everything was working perfectly until I opened a session from an associate who had a SYNC IO and PRO CONTROL. Since then, launching my templates and sessions stall out on 'Loading Peripherals' and hangs for several minutes (5 plus minutes), then finishes. Then once I select my base template, the loading of my tracks stalls out toward the end of the load, then finishes after a couple of minutes (5 plus minutes).
I've upgraded to OSX10.6.7 (combo update installer)
I've re-installed PT updater 8.1.1 (several times)
I've trashed prefs, dae, etc...
I've trashed midi config and re-installed MOTU midi driver
I've tried launching with the ethernet cable de-tached
Any other suggestions would be great. Thanks.
Old 03-24-2012, 08:52 PM
Danny Caccavo Danny Caccavo is offline
Default Re: PT Slow Launch and hangup on Peripherals...
If your associate's session was created earlier than v8.1 and has a complicated bussing/output structure I would recommend downgrading to PT 8.0.5 to see if that works. Assuming you have 8.0.5, of course....
Old 03-26-2012, 09:07 AM
I disconnected the USB (to MTP AV) & ethernet.
I then re-installed 10.6.7 (combo updater)
I then re-installed 8.1.1 (updater)
I then re-installed MOTU MIDI SETUP
Trashed all prefs, databases, dae folder, etc.... (using utility tool)
Fixed HD 'repair permissions'
Restarted from a HD Clone
Inspected & repaired main HD
Fixed main HD 'repair permissions'
Restarted from main HD
Launch PT
And all is great !
Today I'll test reconnecting the USB and ethernet
Pro Tools 10 Not Responding - Slow Launch macdonaldr93 macOS 12 03-14-2014 04:45 AM
Slow pro tools launch roberts Pro Tools 10 3 07-18-2013 08:06 PM
Very, very slow launch! Please, HELP! ND2639 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 06-13-2010 09:56 PM
win7 x64 SLOW Launch Creap 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-28-2010 05:31 PM
Very VERY slow PT Launch TommyT Pro Tools TDM Systems (Mac) 9 06-21-2009 09:14 AM
