HELP!!! Session won\'t open anymore.
I was just finishing the midi parts of a song when after arming an audio track for recording, this warning popped up: “Could not complete your request because of end of file”, so I closed everything and tried to start all over but PT won't let me open the session anymore. I am pretty sure that the midi data is still there in the file because I checked it with Fastfind utility. I wonder if there is a way to recover at least the midi stuff. Or am I just joining the “Lost Work” PT club? Please, HELP!!! [img]images/icons/confused.gif[/img]
Thanks, Antonio. |
Re: HELP!!! Session won\'t open anymore.
Maybe if you created a new session and tried to transfer those tracks into the new session it might work?
Do you defrag your drives often? Are you running out of room on your audio drive? Try a search in the DUC for "Could not complete your request because of end of file" I'm sure others have had similar problems and there are probably answers already in the DUC. Also, try opening your session two ways, 1 start Pro Tools and then do "file" "open", or 2- open up your session from it's folder (PT is closed and opening your session starts PT). Good luck.
Karen Basset Boom Chic Studios Los Angeles, CA 90048 [email protected] http://www.boomchic.com |
Hi Karen,
Maybe if you created a new session and tried to transfer those tracks into the new session it might work? -I tried that with track transfer utility. It works with everything but Midi tracks, which are greyed out. I really don´t much care about audio tracks right now since I'm in the beginning of the recording process, but the midi stuff is a real problem. Anyway, thanks for trying to help. Antonio. |
The Track Transfer Utility has been gone for some time, you should try creating a new session and using "Import Tracks" from under the "File" menu in Pro Tools.
This will allow you to import audio, midi, Aux and video tracks into your new session. Jon Connolly Digidesign Product Specialist |
Also may I add that if you are using 5.1.1 and up. If you set the prefs right, you will have a back-up session folder which may have the last back-up that will have your midi. Good Luck
My System is: Mac Pro 3.2GHz 6 Core 32GB RAM 1- HDX 1 - Apogee Symphony Mk2 8x8 1 - HD 16x16 Interface MOTU MTP/AV ------------------------------ Second System Mac Pro 2013 3.5GHz 6-core Xeon E5-1650v2 32GB RAM 1 - HDX 1 - Avid Thunderbolt 3 Expansion Chassis 1 - HD 8X8 Interface MARVINBASS Digital Audio, LLC Ex PT Beta Tester Woodland Hills, CA. |
I forgot to mention. I'm still running PT under 5.0. Could that be a problem? [img]images/icons/confused.gif[/img]
Antonio. |
Problem solved. It turned out that there was a huge piece of corrupted audio getting in the way every time I tried to open the session. So I trashed it away and voila! Everything is back to normal now. Thank you all for the replies. [img]images/icons/smile.gif[/img] Antonio. |
Pro tools 8 won't open anymore!! | stuffy | Pro Tools M-Powered (Win) | 0 | 03-07-2012 09:28 AM |
Pro Tools does not open at all, anymore... | TTMJP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-05-2010 02:51 AM |
PT won't open on my new iMac anymore | david kowalski | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 05-10-2010 03:40 PM |
Pro tools le 7 won't open anymore | njg27 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 04-26-2010 08:35 AM |
Can not open sessions anymore????? | KroNEe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-22-2002 06:40 PM |
