Old 03-21-2008, 12:31 AM
anal-log anal-log is offline
Default Can\'t import the selected video
Hello all..
I have a Mbox mini, on a Dual 1.42 mdd, running 10.4.9. Tiger
I just updated to 7.4LE and when I try to import video I get the message "Can't import the selected video file because it does not contain any video frames"
So I reinstalled 7.3 and have no problems with the video at all, same session, same video.
Any suggestions?
Old 03-21-2008, 09:24 AM
DigiTechSupt's Avatar
Default Re: Can\'t import the selected video
What format is the video in? Are you trying to import it into a new session or a previously created session?
Avid Audio Tech Support
Support FAQ
Old 03-21-2008, 12:36 PM
The movie is Quicktime H.264, I've tried a new session as well as a previously created session.
Everthing works in PT7.3 but not when I upgrade to PT7.4.
The only way I found out to get it to work in 7.4 is convert to all my videsos to DV.
Whats the difference between PT7.3 and 7.4?
Old 03-22-2008, 03:07 AM
Well finally figured it out.
Pro tools 7.4 does not like "/" not only in the name of the video. You can't have a "/" any where in the path name.
I have my videos in a folder named "Quicktime/Guide tracks" Got rid of the "/" in the folder name and all is well.
Old 03-24-2008, 09:21 AM
jimlongo's Avatar
jimlongo jimlongo is offline
^ ! < > / ( ) - ; are pretty much all illegal in Protools filenames, pathnames, etc.,
you can use them in label names, but anything else is looking for trouble.
noise | jimlongo
Old 03-25-2008, 06:19 PM
mikevarela mikevarela is offline
quick question on that last line.... are you saying that the video file then needs to be in the pro tools folder of the session im workign on.
in my case, i have the video files on a seperate drive (internal) in a folder called video, with sub folders named by projects. i import video into pro tools 7.4 from the dialog and from that seperate drive. of course there are slashes '/' in the file path, because the video resides on another drive. how do i deal with this...
i want the video on another drive because of speed issues.
NuanceTone.com
Old 03-26-2008, 08:35 AM
Phil Ogden Phil Ogden is offline
I think the problem arises if those symbols are used as part of the filename itself e.g "ABC Movie/XYZ Soundtrack" would be a no no as the OS treats the '/' symbol as a part of the path address.
http://www.myspace.com/philogg
Old 04-12-2010, 01:34 PM
jjmoon jjmoon is offline
Default Re: Can't import the selected video
Wow, that just saved me too.
It was an " / " in the video folder name.
Thanks for posting fix.
Unused regions not selected *Video* Top Jimmy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-17-2011 02:13 PM
Help!! Can't import the selected video file. (Pro Tools 8) elsterNJ Post - Surround - Video 2 10-27-2010 06:22 PM
How do I import DVD video to a video track in PT 8?? Sergeman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 06-04-2009 11:08 AM
Video not moving to selected time code puppymachine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-27-2008 12:01 PM
I don't want reverse video on selected area... Mark_Knecht 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-03-2002 11:48 AM
