Old 02-15-2007, 07:12 AM
superxxman superxxman is offline
Default Mixing to external decks such as Masterlink
Hello,
Can anyone tell me how to mix to my Alesis Masterlink using a digital cable connecting from the MBox 2 to the Masterlink? The manual says set clock to "internal" rather than S/PDIF which doesn't make sense and is not enough information for me to do what I need to do.
I'm looking for a step-by-step guide.
Thanks!
Old 02-15-2007, 07:19 AM
jackp jackp is offline
Default Re: Mixing to external decks such as Masterlink
I have My tascam cdrw 2000. spidf in and out from digi 002r does the mbox have both in and out spidf?
I use the spidf in from the tascam, so I can play back cd's into protools. I also mix out to the tascam
sometimes for quick mix, rather than bounce, then burn.
Mac Pro 8 core Protools 10 HD 4 Accel PCI with Magma, C/24 with 2 192 I/O
Isochrone clock
Old 02-15-2007, 07:22 AM
Thanks for writing. I'm not asking what you have, I'm asking how I communicate to Pro Tools that I want to mix to an external source using the S/PDIF. For example I notice there's no way to select output on the master fader?
S
Old 02-15-2007, 08:24 AM
hoodbro1 hoodbro1 is offline
superxxman,
> the "Master Fader" internally controls your tracks main output, which default to "analog 1L/analog2R"
First you'll need to set ALL individual tracks (and their designated master) to SPDIF out.
Visit your IO setup page!
PT must be on internal clock. Feed SPDIF coax cable to your recording device, and set it's sync to "SPDIF/external".
good luck,
hb
Cuts-Only on Sony HD decks jjsoundoc Post - Surround - Video 0 12-21-2007 01:21 PM
Synching to HD decks or 24 fr video dmfisher1 Post - Surround - Video 1 05-16-2007 08:50 AM
Machine Control w/ HD Decks king long fades Post - Surround - Video 0 03-30-2004 03:41 PM
Mixing to the MasterLink Recorder? nukmusic Pro Tools TDM Systems (Mac) 28 11-12-2003 08:17 PM
Please Help DAE Decks Error! DeadPoet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-30-2003 08:20 AM
