Old 02-07-2007, 12:57 AM
Goanna Goanna is offline
Default *Another* crackling sound issue with Mbox 2 Pro
I've just purchased the Mbox 2 Pro and teaching myself ProTools (ha). Have been connecting it to a desktop via FireWire PCI card and 6 pin cable. Mostly no problems. Sound quality good. Both Mbox and software working fine.
Have now tried to connect to a laptop that has only a 4 pin firewire connection. Have connected power supply to Mbox and used a 6 -> 4 pin cable. PT connects to Mbox OK. But when I record or play audio from Mbox there is a crackling sound in output 1/2 and 3/4.
Any ideas what might be causing this? Could it be the cable? Interrupts?
Thanks in advance.
Old 02-08-2007, 04:48 AM
Default Re: *Another* crackling sound issue with Mbox 2 Pro
After a bit more research and noting lack of responses, I think this issue is specific to me.
If I bounce the recorded audio to disk and play it through any old software it sounds fine - no distortion, nothing. So the input has worked fine. Given the distortion only happens when playing back from laptop on Mbox headphone or analogue outputs - and the distortion doesn't happen when playing back from the desktop - it leads me to the conclusion that there is a) nothing wrong with the m box and b) something wrong with the output from the laptop to the mbox. That means either the cable or the port itself.
Old 02-25-2007, 06:09 AM
It was the cable! What are the chances of that?
Mbox 2 Mini - horrible crackling sound after OSX Mountain Lion n4mmo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 12-15-2013 03:10 PM
PT Crackling Static Noise/Sound - Sample Rate Issue gavriil1 Pro Tools 10 5 11-27-2012 06:39 PM
Crackling Issue with Mbox 2 Pro - RESOLVED - rockwilder 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 02-09-2007 12:07 AM
Mbox and windows xp crackling sound Jakob Frandsen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-09-2004 05:05 AM
Crackling ouput/no sound coming out of Mbox jayel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-10-2004 04:49 PM
