Carbon Mon Main Noise
hi everyone
i am running my Avid Carbon Main Out L+R as my studio monitor output. However, this output has a lot of inherent noise. a fairly substantial white noise is present when the Main Out is unattenuated via hardware setup. Anyone else experience this? The bummer is that i designed my 24 track studio thinking i could take advantage of these extra 2 monitor outs to feed my monitor controller. Would be a real bummer to have to instead use 2 channels of the 24... phil |
Re: Carbon Mon Main Noise
What version of Pro Tools are you on (and therefore firmware for the Carbon)?
There have been a few fixes for the Carbon since release in firmware/Pro Tools versions.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Nothing like that here, and I have a pretty sensitive monitoring setup.
Are you using TRS leads (rather than TS)? Any other ambient noise sources (flourescent lights etc)? Apologies if these are all obvious questions. I don't think I've seen another post complaining about output noise on the Carbon, so I'm assuming it's a duff unit, bad cabling or some other combination of unfortunate circumstances, rather than a design flaw in the box itself. Dominic |
It sounds like a mismatch of levels between Carbon and your monitoring amplifiers.
It sounds as if your amplifier is expecting -10dBV and Carbon is sending it +4 dBu line level signal. Are you feeding your monitors from Main Jacks or from LINE 1 and 2 on D-Sub connector? |
In Carbon booklet it says:
Monitor L–R Outputs The Monitor L–R outputs on the back panel are independent of Line Out 1–8 (DB25). Use 1/4-inch TRS (balanced) or 1/4-inch TS (unbalanced) cables to connect these line level outputs to loudspeakers for stereo monitoring. These outputs can be configured to operate at +4 dBu or –10 dBV, and have a maximum operating level of +24 dBu. This setting is on the Line I/O Page of Interface Pro Tools Carbon dialog box. |
Carbon Fan Noise | Halvo | Pro Tools | Carbon | 24 | 10-28-2021 10:27 AM |
Pro Tools Carbon Laptop Fan Noise | Chris August | Pro Tools | Carbon | 39 | 09-08-2021 12:52 PM |
Noise from Main Out L (hardware problem?) | adamqlw | Eleven Rack | 3 | 02-06-2011 07:29 PM |
Noise out of the Main Out | hosea88 | ICON & C|24 | 2 | 10-10-2005 02:21 PM |
Noise in Main Output | Jamble | ProControl, Control|24, Command|8 | 0 | 04-22-2000 09:03 PM |
