Old 06-07-2007, 12:42 PM
Riccardo Corbari Riccardo Corbari is offline
Default faderpack madness
hi. since about a week my faderpack (on a PC with main unit plus faderpack only, total 16 faders) is going crazy.
it startups correctly, then it works for an indefinied amount of time, let's say 20/25 minutes, then randomly it disconnect from pro tools, the faderpack blocks its faders in random position and starts to blink very fast and again random all the leds, then the software pop ups the message of "lost connection". it could re-sync with pro tools in 1 minute or less, then works for about 5 minutes, then re-go crazy...
the utility fader test shows that the faders and the lights are in perfect working order.
what could it be? next week I've a very very very very important artist in my studio and I would have a good working procontrol...
please help, thanks.
Studio Fuoriporta - Italy... verily everywhere...
Old 06-07-2007, 02:33 PM
Pete Gates Pete Gates is offline
Default Re: faderpack madness
That sounds like the power supply is failing - or if you're lucky it could just be oxidised power supply connections, you could try cleaning and reconnection.
Pete
Old 08-31-2007, 10:41 AM
agus agus is offline
I had to replace the capacitors on my power supply. Fixed the same problem.
Not too difficult to do, you just have to find the right caps.
DCommand,FaderPack and XMon 15K..As New postman56 Buy & Sell 9 05-20-2013 07:56 AM
Main unit as Faderpack? Vedat ProControl, Control|24, Command|8 0 07-31-2009 11:25 PM
Faderpack Fail euram ProControl, Control|24, Command|8 3 03-22-2006 04:37 AM
How to get inside the FaderPack airwavejoel ProControl, Control|24, Command|8 9 10-24-2003 11:57 AM
Mute not working on faderpack CHRIS AIKEN Pro Tools TDM Systems (Mac) 2 09-09-2002 04:10 AM
