adjust levels and monitoring help
Hello DUC'ers. Can anyone tell me is there a way I can type in the volume level on a fader (for some reason, I've only been able to move it up and down, but can type the exact volume, i.e. "-12" or "1".
And also is there a way I can see the exact db level on all my meters? |
Re: adjust levels and monitoring help
Yeah if you click the button to bring up the individual channel and then click on the volume you can type it in. Also, if you hold the control key while moving the fader it will move in smaller increments allowing you to set the exact level you want.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
I have one more question, is it possible to direct monitor the s/pdif in with the mbox2? I was able to do this with the analog inputs, but I find I have to make a track first, and arm it in cubase.
Pretty sure the answer to this one is a NO.
Fine adjust fader in edit window caput! command+adjust | crizdee | Pro Tools TDM Systems (Mac) | 2 | 12-09-2008 03:55 PM |
calibration / monitoring levels | louisenslinproduce | General Discussion | 3 | 04-12-2003 03:17 PM |
Any way to adjust input levels? | John Link | Digidesign Hardware & Software | 25 | 06-25-2002 02:26 PM |
need quick help /monitoring levels | msunj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-26-2002 10:39 PM |
Were to adjust a delay in monitoring? | dannepop | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-02-2002 12:45 AM |
