Plugin presets aren't compatible between DAWs?
Hey guys I've been using Studio One a lot but still mixing in Pro Tools. Got plugins and presets saved from Studio One and now trying to load them in Pro Tools but they're a different format? I thought plugin presets can be loaded into the same plugin no matter which daw you're using. Anyways this is killing my creative flow right now and would rather be mixing than googling so I apologize if this has already been covered. I did search but it was a half ass search. Gonna post in Studio One forum and see what they say.
Thanks! |
Re: Plugin presets aren't compatible between DAWs?
Nope. Each are saved according to the type of plugin ( AAX, VST, AU) and are not cross compatible. Wish they were.
Regards, Ned Monkey Boy Studios 2019 16" MBP, 32GB, 1TB SSD; OSX 10.15.7; 4TB USB-C G-Tech External Summit Audio 2BA-221, TLA-50 -->Focusrite 18i20 3rd Gen, Eleven Rack, Pro Tools 2021.3 Plugins, Virtual Instruments, and real ones |
Nevermind. I thought the DAW preset saving option was universal. Totally overlooked the plugin's own save option.
If a plugin has it's own preset management system, you can usually transfer presets between DAWs. But, as you know, you can't do that with the DAW specific preset option.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
OP
Seen some pretty cool stuff using Blue Cat Software Patchwork. Patchwork looks like a plugin host that can host VSTs in Pro Tools - and much more. So, if you make a plugin Chain in Studio One in Patchwork, you can use the entire chain in Pro Tools as is. Can do VIs as well apparently. I need to try this. Looks like a good workflow compromise for people that must work in multiple DAWs. e https://www.avid.com/plugins/patchwork Last edited by ejinbc; 02-11-2021 at 06:00 PM. |
Sounds like all new MacBook Pros aren't compatible with Firewire devices. | Focuret | FireWire & USB Audio Interfaces (Mac) | 13 | 11-22-2016 03:40 PM |
Anyone else have issues with Plugin Alliance Rtas plugin presets? | realizment | Windows | 0 | 04-01-2015 05:04 AM |
Hypercontrol: Convert plugin build-in presets to pro tools plugin presets | headsup | macOS | 4 | 12-17-2011 01:28 PM |
Mbox2 Compatible with other DAWs? | me beginner | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 03-20-2011 09:06 PM |
Hybrid Is A Wonderful Synth. Why Aren't There More Presets Available? | epu | Virtual Instruments | 11 | 10-12-2010 02:40 PM |
